Old 07-09-2014, 01:15 AM   #1
Year: 90
Chassis: international
Running heating vents along ceiling
In the process of doing my bus build I find I made a bit of a blunder in being able to run heat to the front of the bus.
Basically the furnace is aft of the fridge blocking ducting to the front. Running the ducting under the bus is possible but will be a pia to snake it around the fuel tank and inboard of the frame.
My thought is to run an overhead duct over the fridge, (there's room) and to a shallow channel (2x6) along the ceiling. Only needs to go 5 ft and will be run over the kitchen just outside of the factory ceiling lites. with small vents along the length.
Has anyone done this ? how does it work.
BTW just recently got insurance on it. National Insurance is the way to go. Great experience.
Old 07-09-2014, 07:13 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Running heating vents along ceiling
While it will probably work to get the heat near the front, remember that heat rises. If you don't run the duct back down to the floor it will just stay at the ceiling.
Old 07-11-2014, 02:12 AM   #3
turf's Avatar
my heating ducts were certainly an afterthought and i wish i had considered them much sooner in my build.
for a while i considered an overhead duct. i settled on lifting one cabinet enough over the wheel well for the duct to pass through.
the path of the return air also will help distribute the heat. i was fortunate to run the return air from the front of the bus back to the heater through the existing bus wall.
Turfmobile Build Thread
turf is online now   Reply With Quote
Cabin Heating, Water Heating Locutus Heating, Cooling and Appliances 2 11-01-2014 04:34 PM
leaking ceiling vents jjhomeonewheels Conversion General Discussions 5 02-27-2014 02:10 PM
Plumbing vents Papabear Conversion General Discussions 3 02-09-2010 05:38 PM
Roof Vents frank-id Everything Else | General Skoolie Discussions 0 01-14-2008 11:45 AM
Modify stock heating system or seak alt heating? phillbus914 Conversion General Discussions 4 09-14-2005 05:14 PM
