Old 06-17-2012, 10:06 PM   #1
Chassis: Bluebird
Engine: International something
Running lights not working
When I first turn them on they all light up and are fine, however 45 seconds to a minute later they all go out. Has anyone had this problem before any suggestions? No fuses are blown. I have replaced all the bulbs. Any help would be great!
garbemi is offline   Reply With Quote
Old 06-18-2012, 09:44 AM   #2
Stuff's Avatar
Re: Running lights not working
clearance lights or headlights? if its DRL it could be an oil pressure sensor for them?
Old 06-18-2012, 10:21 AM   #3
that's right. just turn the parking lights on by themselves and check. if they stay on, then it's in the headlight wiring..like the relay or circuit breaker. having installed many off road lights, i have found that if one wires the main off road wire to the headlights, the overload will eventually trip the cirucit breaker... when you are driving ....
Old 06-18-2012, 01:37 PM   #4
browncrown's Avatar
Rated Cap: 79 at Birth
Had this problem with my headlights. Turns out it was a faulty dimmer switch causing the circuit breaker to pop.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Running new Wiring for lights? Thundarfoot Electrical, Charging and Solar 17 07-31-2022 09:35 AM
Running Lights and tail lights not working bapos Alternative Fuels | Electric, Propane, Wood & Biofuels 2 12-14-2011 11:32 AM
inner running lights headin2MT Conversion General Discussions 2 03-02-2011 05:40 PM
Tail lights,running lights not working putterspitt Conversion General Discussions 2 10-12-2010 05:19 PM
LED running lights adamanderr Conversion General Discussions 2 03-13-2008 02:40 AM
