Old 08-14-2018, 11:51 PM   #1
anjay02's Avatar
Running wire
Where can we find info in regards to running wire for a 50amp with ideas and such? Much like the same as RVs just in case anyone asks. I plan to do the same setup.
Thank you,
anjay02 is offline   Reply With Quote
Old 08-15-2018, 06:10 AM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Howdy and Welcome John!
Are you looking for technical specs/requirements or wiring diagrams/parts?
If the latter, my diagram and description is here. It is one of the less basic variants.
JD - Full timer out west
My Adventures & Build
Old 08-16-2018, 08:24 AM   #3
bubb, the real one's Avatar
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
I assume you are talking about installing a 50 amp shore power receptical,
the receptical you need to install on the outside of the bus is a 14-50R, it looks like a 240v receptical but it is not it only has 120v running through it, so dont let it get wired wrong or it will fry everything you plug into it.
From that outside receptical to the breaker panel you probably want 6ga wire,
From the breaker panel to your wall recepticals and lights 12g is best for up to a 20 amp receptical,
14g wire is ok if it is a 15amp receptical or less.
my bus thread, https://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
bubb, the real one is offline   Reply With Quote
Old 08-17-2018, 10:56 PM   #4
anjay02's Avatar
Thank you that is just what I am looking for!
Thank you,
Old 08-20-2018, 08:11 AM   #5
Engine: 466e
Rated Cap: its Yuge
I was under the impression that it was 50 amp 240. Now I'm not sure purchased the correct plug. Havent installed yet
MambaJack is offline   Reply With Quote
Old 08-20-2018, 09:55 AM   #6
anjay02's Avatar
That plug is fine. I am just looking for a wiring diagram or possible pics just to get ideas.
Thank you,
Old 08-21-2018, 04:17 AM   #7
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
The correct receptacle (or typically found at RV parks) for "50 amp shore power" is a 14-50R - this is a four wire receptacle. There is a lot of confusion over what the power is. In the USA, it is 220 volt power. However; that is accomplished using two 110 volt legs. In terms of RV use, each leg is pulled off and used individually (50 amps @ 110VAC). Thus; you have a total of 100 amps @ 110VAC.
Old 09-02-2018, 11:20 AM   #8
Off topic sorry!
Nice 6x6 in your avatar photo.
What is it and what year?
I have a 1951 M135 that I plan on stretching and puttin my 1951 bus body on.
if your not already a member check out Steel Soldiers.
You can email me at martincityventures@gmail.com
Blessings to you and yours!
Monte
MCV1964 is offline   Reply With Quote
