Old 09-30-2016, 04:28 PM   #11
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by slaughridge85 View Post
Ospho - OSPHO Rust Converter/Metal Primer | West Marine
You can get it at most home improvement stores including ACE hardware. Its cheap, does a great job and has detailed instructions.
I've used this product on an industrial level to acid etch/clean aluminum stock trailers after welding and before paint. Used to get it in 500 gallon tanks. Works like a charm.
THIS^^^
Roll Your Own Build Thread
Old 09-30-2016, 04:30 PM   #12
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by Kylebetaclark View Post
Awesome... this is the type of lead I was looking for... a fraction of the price (assuming it does a decent job) of the small bottles. Then move onto one of the coatings ^ identified above.
Thanks!
It does a great job. I get gallons jugs at Ace for $25.
Old 09-30-2016, 04:38 PM   #13
Engine: 5.9L Cummins
Anyone know of a Canadian Ospho distributor?
-cycosis- is offline   Reply With Quote
Old 09-30-2016, 04:52 PM   #14
Check with your local paint stores, or suppliers. I have found it in several places.
Good luck
1olfart is offline   Reply With Quote
Old 09-30-2016, 05:02 PM   #15
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
Originally Posted by Bell View Post
Thanks for the link, but I'm wondering, will 3 gallons really be necessary?
Old 09-30-2016, 05:15 PM   #16
Rated Cap: Your mom +1
Originally Posted by -cycosis- View Post
How much ospho have people been buying to successfully do their floors?
I bought the gallon to prep the sides of my bus where I added bare sheet metal after the roof raise and window delete. I did both sides and the front and back of the exterior and I used maybe 1/3 of a gallon. It's almost a water like consistency, maybe just a touch thicker. Lasts forever and when I was using it on the stock trailers at an old job we just ran it through a power washer and sprayed down the trailers. BTW Ospho is just a brand name for "Phosphoric Acid" so you may have better luck trying to find that if Ospho isn't available in your area...
Old 09-30-2016, 05:31 PM   #17
Chassis: International S3800
is ospho better than POR-15?
or a different purpose?
Old 09-30-2016, 05:42 PM   #18
Ospho is a rust convertor. When the acid reacts with rust it forms iron phosphate, turning the metal black. You then REMOVE the Ospho residue and then paint over it with primer. The best procedure is to use a wire wheel or sandblast the rust down to bare metal and treat with Ospho, remove the residue (with soapy water) and then prime and paint.
POR-15 is a rust encapsulator. It does not convert the rust to anything. It simply encapsulates it in a REALLY hard paint shell so no oxygen can get to it, thus stopping further rust. POR-15 has a very specific application procedure and works best on rusty, but well-prepared metal. If the metal is too smooth the POR-15 will peel off like electrical tape. POR-15 is also not UV safe - it will turn milky and chalky from sunlight.
Which to use depends on what you are trying to do, how well you can prep the surface, how you can apply it. For rusty frame rails you can do either but it might be easier to use POR-15, though it will probably cost more. That stuff is expensive. They do have some new products that apply over POR-15 rust encapsulator, like chasis paints (to provide UV protection). If you topcoat it, you have to do it before it cures or else sand it, which is almost impossible.
Old 09-30-2016, 10:27 PM   #19
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I've always thought the POR-15 was way overpriced.
Been using Ospho since auto body school back in the mid 90's.
Old 09-30-2016, 10:33 PM   #20
I have always used POR-15 underneath cars and in areas where i wasnt easily able to get a wire wheel but i could get a wire brush and a paint brush... sounds like what I have used it for is its purpose.. its good to know that its not meant for bare metal or for sunlight areas..
yes its expensive but it was always something i put on and then never covered up.. it wasnt meant to look pretty but was meant to stop further rusting..
all i typically did on the cars was a stiff wire brush after a 150 PSI air hose.. then painted it on... and I wore pretty uch a hazmat suit to apply it as ive been told if you get it on you then its there for good... i never took that chance..
I dont know how ospho is but sounds like i should try it where i need it on the carpenter bus in spots.. is it nasty if you get it on you or can it be removed with mineral spirits?
