Old 04-06-2011, 09:02 AM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Re: RV air conditioner install issues on bus?
One issue you may have is that the metal is thin and the wieght of the AC will bend it. I think many people (including myself) put some sort of bracing between the layers of the ceiling and roof to take up the space and prevent the sagging of the upper roof metal. Although a little bit of sagging may actually help level out any curvature. I cut some 2" pieces of wood and used that to fill the gap and attach the upper unit to the roof.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 04-06-2011, 11:40 AM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
id suggest browsing builds on here where they have installed AC's. if i remember right it isnt a big deal.
Old 04-06-2011, 10:51 PM   #3
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
I used 2" styrofoam from an insulated panel used for sunroom walls to between the inner and outer layer. fit tight and insulated a little. It has an aluminum skin on it to make it rigid
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Air Brake Issues porkchopsandwiches Mechanical and Drivetrains 8 02-18-2014 11:45 AM
Air Conditioner knucklehead Conversion General Discussions 2 02-21-2011 03:00 PM
floor issues butcher_boy Conversion General Discussions 2 10-08-2010 11:48 AM
Anybody need a $50 air conditioner? boojiewoojie Conversion General Discussions 5 03-14-2007 10:50 AM
Build your own Air Conditioner Steve Conversion General Discussions 7 03-30-2005 12:25 AM
