Old 09-23-2019, 03:12 PM   #1
ewo1's Avatar
RV driver license requirements - State Listings
Here is a listing I found showing what is required from each state to drive an RV.
From my basic non professional understanding, what your HOME state requirement is , and the tag on the bus should be from your home state, follows you across the country as you drive away into the sunset.
SOURCE:-> https://www.campanda.com/magazine/rv...-requirements/
States That Require A Commercial Driver’s License
  • Arkansas: CDL required for vehicle over 26,000 lb
  • Connecticut: CDL (Class B) required for single vehicle over 26,000 lb; CDL (Class A) required for multiple vehicles with combined weight over 26,000 lb
  • Hawaii: CDL (Class B) required for single vehicle over 26,000 lb; CDL (Class A) required for multiple vehicles with combined weight over 26,000 lb
  • Kansas: CDL (Class B) required for single vehicle over 26,000 lb; CDL (Class A) required for multiple vehicles with combined weight over 26,000 lb
  • New Mexico: CDL (Class B) required for single vehicle over 26,000 lb; CDL (Class A) required for multiple vehicles with combined weight over 26,000 lb
  • Washington, D.C.: CDL (Class B) required for single vehicle over 26,000 lb; CDL (Class A) required for multiple vehicles with combined weight over 26,000 lb
  • Wisconsin: CDL required over 45 feet
States That Require A Non-Commercial Special Driver’s License
  • California: Class B license required over 26,000 lb or over 40 feet; Class A license required for towing over 10,000 lbs
  • Maryland: Class B license required over 26,000 lb
  • Michigan: Recreational Double “R” Endorsement required to tow a fifth wheel plus a trailer (it’s unlikely that you’ll ever need this)
  • North Carolina: Class B license required for single vehicle over 26,000 lb; Class A license required for multiple vehicles with combined weight over 26,000 lb
  • Nevada: Class B license required for single vehicle over 26,000 lb; Class A license required for multiple vehicles with combined weight over 26,000 lb; “J” Endorsement required to tow a vehicle over 10,000 lb (if the combined weight is less than 26,000 lb)
  • New York: Recreational Vehicle or “R” endorsement required for vehicles over 26,000 lb
  • Pennsylvania: Class B license required for single vehicle over 26,000 lb; equired for multiple vehicles with combined weight over 26,000 lb
  • South Carolina: Class E license required for single vehicle over 26,000 lb; Class F license required for multiple vehicles with combined weight over 26,000 lb
  • Texas: Class B license required for single vehicle over 26,000 lb; Class A license required for multiple vehicles with combined weight over 26,000 lb
  • Wyoming: Class B license required for vehicle over 26,000 lb and towing under 10,000 lb; Class A license required for vehicle over 26,000 lb and towing over 10,000 lb
States That Do Not Require A Special Driver’s License
The following states do not require a special driver’s license to drive an RV. Where possible, we have provided links to the relevant state laws where the exemption for recreational vehicles can be found. Remember: When in doubt, contact your local DMV.
Alabama (Ala. Code § 32-6-49.7)
Montana (§ 61-1-101, MCA.)
Alaska (AS § 28.90.990)
Nebraska (Neb. Rev. Stat. § 60-465)
Arizona (Ark. Code § 28-3102)
New Hampshire (N.H. § Saf-C 1801.02)
Colorado (Colo. Rev. Stat. § 42-2-402)
New Jersey (N.J. Rev. Stat § 39:3-10.11)
Delaware (Del. Admin. Code tit. 2 § 2213)
North Dakota (N.D.C.C. § 39-06.2-06)
Florida (Fla. Stat. § 332.53)
Ohio (Ohio Rev. Code § 4506.3)
Georgia (OCGA § 40-5-142)
Oklahoma (47 O.S. § 1-107.4)
Idaho (I.C. § 49-302)
Oregon (Or. Rev. Stat § 801.20
Illinois (625 ILCS § 5/6-500)
Rhode Island (31 R.I. Gen. Laws § 10.3-16)
Indiana (CDL Manual)
South Dakota (S.D. Codified Laws § 32-9-3)
Iowa (Iowa Code §321.176A)
Tennessee (T.C.A § 55-50-102)
Kentucky (KRS § 281A-050 and CDL Manual)
Utah (Utah Code § 53-3-102)
Louisiana ( LSA-RS § 32:40
Vermont (23 V.S.A § 39-4103)
Maine (29A M.R.S § 1252 and CDL manual)
Virginia (Code § 46.2-341.4)
Massachusetts (DMV.org)
Washington (RCW 46 25-050)
Minnesota (Minn. Stat. § 169.011 or driver’s manual)
West Virginia (W. Va. Code § 17E-1)
Mississippi (Miss. Code § 63-1-203)
Missouri (MO Rev Stat § 302.775)
Old 09-23-2019, 03:18 PM   #2
Or into the sunrise.
Registered in Vt. Licensed in Ga., I'm good.
Old 03-18-2024, 08:21 PM   #3
s2mikon's Avatar
Engine: Cummins 8.3
Here is the exemption for New Mexico. New Mexico Class E (CDL exempt) license
By rule (18.19.5.112 NMAC) drivers with a Class E license may operate certain vehicles that are over 26,000 pounds on the public roads and highways of New Mexico without a commercial driver’s license. The Class E exempt license is available to drivers of:
Recreational Vehicles – vehicles that are registered and used as recreational vehicles.
Farm and Ranch Vehicles – vehicles that are:
• controlled and operated by a farmer or rancher or an employee of a farmer or rancher;
• used to transport agricultural products, agricultural machinery or agricultural supplies to or from a farm or ranch;
• used within 150 miles of the ranch or farm; and
• not used in the operations of a motor carrier or otherwise used “for hire.”
Fire Fighting Vehicles – vehicles manufactured for and equipped to fight fires and equipped with audible and visual signals and operated by a person who is a member of a volunteer or paid fire organization.
Military Vehicles – all vehicles owned or operated by the Department of Defense and operated by non-civilian operators. [Note: Military drivers are, however, typically licensed by the military, so would not normally need a New Mexico Class E license.]
Vehicle Certification
All first time applicants for a Class E license must provide a Vehicle Certification form (MVD-10414).
THIS IS YOUR DOCUMENTATION FOR WHY YOU ISSUED THE EXEMPTION. MAKE SURE THAT THE APPLICANT IS QUALIFIED TO RECEIVE IT.
RV driver – may sign for himself.
Farm or Ranch – owner may sign for himself; however, the farmer/rancher must sign for employee-applicants.
Fire Fighters – Fire Chief must sign.
s2mikon is offline   Reply With Quote
