Old 12-19-2016, 05:24 PM   #1
RV Window Question- Flush Mount?
I'm taking measurements and planning out what size windows to order.
I like the look of the new flush mount style rv windows. Does anyone have any experience with them? How would they work in my application?
Do they only work with a trim ring? They sure would look rad.
Seems that with trim rings, about 2" wall thickness is the maximum. I could maybe be good with this as I'm mostly going to be using this thing as a weekend warrior for trips around the sunshine state and the southeast.
What yall think?
Roll Your Own Build Thread
Old 12-19-2016, 08:23 PM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
we took my friends window out to change out an rv fridge with a home model. it was a 2011 model with insulated glass. it had a flange on the outside that you screwed thru with trim strips that covered all the screws. the flange was about 3/4 ".the inside trim would fit snug and would adjust to the thickness of the wall. but that was a wall on the slide out maybe 2" thick. this was a horizontal roller type window.
my build pics
Old 12-22-2016, 12:52 PM   #3
How do the newer "frameless" style rv widows mount? Can I use them without a trim ring?
These look nice and will hold up better over time it would seem-
Old 04-11-2017, 05:43 PM   #4
Coachwork: Thomas Saf-T-Liner
Apologies for bringing up an oldish thread. Where you ever able to find out anything about the frameless windows? Like how they mount? I'm also looking at windows and was thinking about the frameless ones.
Sent from my SM-T350 using Tapatalk
nwarner2010 is offline   Reply With Quote
Old 04-11-2017, 06:17 PM   #5
Im still pricing and shopping, and NO- I haven't been able to find out about the frameless style.
Good thread to BUMP to the top!!
Anyone know about these damned windows?
Old 04-11-2017, 08:34 PM   #6
You can use them. I used some wood strips with long screws as a temporary trim to clamp the window and get a good squish on the butyl tape. After it sits for a couple warmer days just screw and shim like a normal house replacement window. A lot of the windows on eBay don't come with trim rings.
Trailer2 is offline   Reply With Quote
Old 04-11-2017, 08:48 PM   #7
Would you happen to have any pictures of the process? I was looking at ebay windows, wasn't sure if the trim rings are needed or not. It seems some people just screw the normal framed windows from the outside and just trim the inside when buying the ebay windows.
Old 04-11-2017, 09:28 PM   #8
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
I can't put my hand to it at the moment, but I saw a video on youtube of someone converting a panel van to a camper. The video showed how to drill out the panels and attach the windows. The fellow doing the conversion tied off the suction holders (while holding the glass) to the frame on the other side of the van to hold pressure on the window while the butyl tape "set up". I thought it was quite ingenious....
MarkyDee is offline   Reply With Quote
Old 04-13-2017, 08:41 PM   #9
You need to see how they put the windshields in rvs. My is scary. Lol
Seriousracer is offline   Reply With Quote
