Old 04-20-2018, 01:17 PM   #1
Coachwork: Freightliner Thomas
Engine: 5.9L Cummins Diesel
Rated Cap: 71
RV windows?
Hi folks,
Iíve several times seen people on here say that school bus windows are terrible and that replacing with RV windows is a good idea. A few questions:
- Are RV windows actually much better (particularly for their cost)? We havenít seen that those have great R values either, for example. We absolutely do not want anything tinted.
- We intend to have curtains, probably heavy ones for winter nights and light ones for cutting glare/heat gain during the day. Should we still consider RV windows or will the curtains do the trick?
- If we wanted to put in RV windows, where would we get them? Weíd prefer to get used ones (e.g. off of scrap RVs) rather than new if possible. How much should we expect them to cost?
- How do we make the new windows fit? Iím sure school bus and RV windows are not the same dimensions. How does installation work?
Any other advice on windows and RV windows that Iím not thinking to ask?
Thanks!!
olives is offline   Reply With Quote
Old 04-20-2018, 02:09 PM   #2
The proper way to fit RV windows would be to remove the old windows, weld in framework the size of the new windows and then reskin the outside and cut out the window opening and install the RV window. It's not an easy plug and play type situation, but worth the effort for the final results.
You just need to search RV salvage in your area or hit up Craigslist and Ebay places for used windows.
Old 04-20-2018, 04:08 PM   #3
Marc covered it pretty well.
I will add that there are double pane RV windows that are a world better than RV windows.
They are available on eBay as well.
Old 04-22-2018, 10:52 AM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I have RV windows Iím not using if anyone is interested. Located in Chattanooga.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 04-22-2018, 12:12 PM   #5
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Are yours double pane?
2martins is offline   Reply With Quote
Old 04-22-2018, 12:33 PM   #6
I meant "better than bus windows".....
Old 04-22-2018, 12:36 PM   #7
on thing for sure is that school bus windows are known to leak in heavy or sideways rains.. not all do but many do.. R value isnt everything.. the panoramic view and tightness against water of RV windows is a world better than school bus windows..
Old 04-22-2018, 05:57 PM   #8
Rated Cap: 71
Thanks for all this feedback! If I'm putting in RV windows, what if they are wider than the school bus windows - do I wind up cutting through those structural beams (that on the floor are called frame rails?) and how do I avoid damaging the structure/strength of the bus?
Also, I've read that double-paned windows are a bad idea in a vehicle (even ones meant for RVs) because they start to leak a bit of air and then get condensation between the panes. Anyone know anything about this?
Also, anyone installed RV windows before and interested in helping us with this? Somewhere along the east coast -ish or Northeastern U.S. would be great.
Thanks!
Old 04-22-2018, 07:06 PM   #9
Chassis: Saf-T-Liner MVP ER
Thanks!
You make a cantilever frame.
Where you cut out a rib you add horizontal pieces of square tube to frame the upper and lower window edges, and vertical pieces for the sides. The cut rib is welded to that new frame and strength is retained.
Steve Bracken
Build Thread
Old 04-22-2018, 09:47 PM   #10
I'm interested in what you might have in windows David. You're close enough to me to pick them up.
Old 04-22-2018, 09:59 PM   #11
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
i did the exact thing you're wondering and what they are talking about. i found 9 used rv windows for $135. got pretty lucky though. even a frosted one for the bathroom. non tinted too. a lot were wider than 2 1/2' about the space between ribs. which i welded square tubing in between the ribs that were cut like mentioned and then around the window as well. plasma cut out the openings and rivet them in to the new bus skin.
it will all make a lot more sense to you when you completely strip your bus down, if you havent already.
BurlKing is offline   Reply With Quote
Old 01-23-2020, 01:21 PM   #12
Chassis: TC1000 FE
Engine: 5.9
Is it necessary to weld in a new framework for a window? What would be wrong with cutting out the opening just through the interior plywood and exterior skin and installing it like that?
lebusmagique is offline   Reply With Quote
Old 01-23-2020, 02:41 PM   #13
DoxieLuvr2015's Avatar
Chassis: S2
Engine: 6.4 MBE 906
Ughh reading this thread makes me really do the extra work and remove a portion of the bus windows and replace with RV windows. Maybe the best of both worlds lol
🚌 2004 Freightliner 30', MBE 906 6.4L, AT 2500PTS
DoxieLuvr2015 is offline   Reply With Quote
