Old 08-26-2015, 07:48 AM   #21
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I don't need no stinking parental approval.
P.S. Don't forget to feed the gremlins.
I'm hungry!
You Gotta Let Me Fly
Old 08-26-2015, 11:12 AM   #22
be careful not to drop a panel and cut yourself
Old 08-26-2015, 04:58 PM   #23
Chassis: TC2000 RE
Engine: 8.3l Cummins
How are they going to loosen at all? Rivets form a tight compression joint between one more more layers of sheets and the rivet itself.
Unless you are stretching the rivet components to failure, in which you are doomed anyway, you will not be loosening anything.
Edit:
I'd like to have you perform a thought experiment.
Imagine two soup cans, one is slightly smaller than the other. You then attempt to crush the soup cans by stepping on their side walls. Note that both cans crush together.
Now, take a single soup can, and crush in the same way. It still smashes the same as double soup cans.
Dammed if you do, dammed if you don't.
Look at the size of the bus body, and the thickness between the outer skin and the inner skin. In order to cause the combination of inner and outer skin with crossbeam elements to create a boxed structure, there needs to be a favorable ratio of space to the transverse box elements.
When you only have a tiny piece of hat channel or space between the two, the actual additional strength formed is very little. Sure, the inner skin helps - but it's more about manufacturing aesthetics, physical thickness to install things such as lights, speakers, and other components, as well as comfort issues such as thermal load and reducing exposure to condensation.
It just happens that riveting an interior set of panels is convenient because the factory is already working with steel for one, and two you DO gain a small amount of strength, which makes sense since we're constructing big steel boxes to carry children around.
Which vehicle is an entity going to purchase with safety and durability the #1 choice:
The vehicle with the steel exterior and plush composite interior that while nice, is slightly less strong than that other guy's steel box, requires special attention to take care of the finish, and can get destroyed by children.
The vehicle with the steel exterior and steel interior, that isn't quite as nice, but is a little stronger than that other guy's steel box, requires zero to very little attention to take care of the finish, and is nearly indestructible to children.
Id wager that most steel interiors in school buses is more about economy and durability of it's cargo, than anything to do directly with strength.
Originally Posted by kennythebus View Post
So my dad is still upset about this. He said that the outside rivets will loosen more quickly without the interior skins. Did anyone experience that?
aaronsb is offline   Reply With Quote
Old 08-26-2015, 05:27 PM   #24
Originally Posted by aaronsb View Post
i
id wager that most steel interiors in school buses is more about economy and durability of it's cargo, than anything to do directly with strength.
this ^^^^^^^^
Old 08-26-2015, 10:40 PM   #25
Rivet the two soup cans together and try again.
Old 08-27-2015, 05:16 AM   #26
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
And military personnel.
One other thing to consider- if the interior steel were structural, then why isn't it as thick as the exterior cladding? Because it's primarily, as Aaron pointed out, a thermal break and something for bored kids on the ride to/from school to kick.
Captain Obvious on deviantArt
Old 08-27-2015, 08:14 PM   #27
kennythebus's Avatar
Coachwork: International Harvester
All of this is very helpful. They're coming out. Free the Gremlins!
kennythebus is offline   Reply With Quote
Old 08-27-2015, 08:42 PM   #28
Moderator
crazycal's Avatar
Are gremlins edible? I'm hungry. Maybe I can mix one in with the soup.
I'm hungry!
Old 08-28-2015, 08:41 AM   #29
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Mix it in with the unicorn for stew
Old 08-28-2015, 10:54 PM   #30
They're edible and delicious but suuuuppppeerrrr high in cholesterol.
Old 08-29-2015, 05:22 AM   #31
Chassis: Amtran
Rated Cap: 71
They can be mischievous and like to hide tools and bus parts.
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
