Old 08-21-2015, 02:50 PM   #1
kennythebus's Avatar
Coachwork: International Harvester
Safe to remove interior walls?
Hey I'm Lauren and I want to pick your brains. So I've been removing rivets from the interior of my bus so that I can remove the metal side panels, but my dad is really concerned that this will lead to the bus becoming deformed. He thinks that the piece of metal is vital for the structure and is meant to keep the bus from bending. I'd love to hear thoughts from all the bright, intelligent and experienced people logged in.
kennythebus is offline   Reply With Quote
Old 08-21-2015, 03:11 PM   #2
It won't deform anything. The interior panels are best removed and scrapped or repurposed. They trap the moisture that naturally builds on the metal panels.
The structural element of the interior skins is so minimal, its insignificant. Out with em!!!!!
Old 08-21-2015, 03:33 PM   #3
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
What he said.
Captain Obvious on deviantArt
Old 08-21-2015, 05:04 PM   #4
I should have taken pics of the condensation I saw this morning in my bus. The walls and ceilings were literally sweating bullets.
Old 08-21-2015, 06:01 PM   #5
Thanks guys!
Old 08-21-2015, 06:58 PM   #6
Engine: 190hp 5.9 Cummins
You need to go do some reading in the build thread section.
If you had, you would not have asked that question.
We have the answer to every question in the build thread section.
Old 08-21-2015, 09:27 PM   #7
Yeah sorry. I was reading them for a bit. I found a bunch on how to remove them, but not as much about if it was okay.
Old 08-22-2015, 07:33 AM   #8
Chassis: Amtran
Rated Cap: 71
Do not remove the side panels, the bus gremlins live in there, do not awaken them, they will cause muck havoc! Seriously, no problem go ahead and pull them down, it will allow you to inspect for leaks and mold and add new insulation.
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 08-22-2015, 10:17 AM   #9
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
This is true.
I'm hungry!
You Gotta Let Me Fly
Old 08-22-2015, 10:30 AM   #10
There are varying opinions on this topic that have been tossed about in the past, so I might as well jump in and re-start this "lively" conversation.
Always fine to remove interior sheet metal, clean, re-insulate, whatever.
But...I was advised years ago by a retired Blue Bird engineer that it should go back in. The nature of the shell design on nearly all metal bodied buses relies on the box beam effect created by the two separate skins attached to the ribs inside & out. And no...this is not just for "roll over" protection...it was described to me as basic to the original design's structural integrity.
OK..I said it (again). Jump all over it. Or...ask a qualified structural engineer to compare the two design options.
I opted to keep both skins on my old 40' Bird and on the little Wayne I am working on now. Everyone here is also free to make whatever choice suits their fancy as well. I am not saying that my choice is the only "right" one, just passing on what I considered to be information worth considering from a reliable source. What I am proposing is that you try to get as much qualified info as possible to base your choices on. Especially as regards the fundamental structure.
Old 08-22-2015, 12:05 PM   #11
Moderator
crazycal's Avatar
I agree with this...and the gremlins.
I'm hungry!
Old 08-22-2015, 07:41 PM   #12
We have rolled full size 66 passenger buses down a hill with the excavator when cleaning up a spot for the crusher.
Two out of 5 had no interior panels. However, the two without didn't deform any more than the three that still had the interior panels.
A few dents, and none of the 5 where still square inside. That was the extent of the damage.
That's what I based my dissension on.
Old 08-25-2015, 09:13 AM   #13
Alright so what it sounds like from what I've read here and on other sites is that the interior skins were designed to help reinforce the bus and make it stronger, but they aren't vital. A lot of people have removed the skins and experienced no problems as long as they make nice with the gremlins.
Old 08-25-2015, 12:41 PM   #14
What would make you feel better- mold and funk hidden in your hot or cold (depending on the weather) metal interior walls, or .0000000000000001% less crash worthiness?
Sounds like you're playing it smart... asking questions FIRST! just weigh all your options and consider it all and then make an informed personal decision.
Old 08-25-2015, 01:28 PM   #15
Chassis: B3800 Short bus
Best job ever... I would pay for tickets to watch that!
Old 08-25-2015, 02:17 PM   #16
I hate buses getting crushed. They crushed just over 100 when I first stared working for them.
It feels like a waste of good parts.
Old 08-25-2015, 05:44 PM   #17
So my dad is still upset about this. He said that the outside rivets will loosen more quickly without the interior skins. Did anyone experience that?
Old 08-25-2015, 06:06 PM   #18
I drive down some crappy roads and haven't noticed and rivets loosening. They're totally unrelated.
Just speaking from my personal experience but skoolies and parental approval RARELY go hand in hand in any regard.
Old 08-26-2015, 12:00 AM   #19
Show your dad this site.
Show him the input of all the people with Real bus experience. Not just a Opinion.
There are far to many of us here that have removed the interior skin with no negative effects.
Old 08-26-2015, 07:00 AM   #20
austin1989us's Avatar
Chassis: TC/2000
Engine: Cummins 5.9TA
I love my father-in-law, and when I bought the bus we were working on it together a lot. But I quit working on it with him a while ago. He's got a lot of opinions and they're slowing me down. People on this forum have opinions too. Don't let them slow you down either.
austin1989us is offline   Reply With Quote
