Old 08-16-2016, 08:46 AM   #1
Coachwork: Gillig
Engine: Detroit Diesel 6V92
School BUs Tinted Windows
I have a possible opportunity to get all of my windows replaced with factory tinted bus windows. A local scarp yard was helping me find a replacement for one I broke... and when they brought me two TINTED windows, my eyes lit up. I can likely replace all of mine for around $300. While I know there are people who talk about the inefficiency of the bus windows, I wondered if any had experience with the tinted variety. $300 is a whole lot cheaper than a couple RV windows, and since we aren't living in it full time, and instead just camping, I just thought I would check to see if anyone and experience with them in terms of blocking some heat from the sun as well as privacy (obviously that depends on how dark they are but I was just curious).
Thank, everyone!
lanegordon is offline   Reply With Quote
Old 08-16-2016, 09:01 AM   #2
FlyboyHPD's Avatar
As inefficient as our school bus windows are I'm of the belief that every little bit helps. My bus came with tinted windows and I really like that fact. Tinted windows in combination with a white insulating paint on the roof can make a big difference in the reduction of heat getting into the bus. Good luck with whatever you choose.
1999 International AmTran, DT466E, MD3060
https://flyboyrv.wordpress.com/
FlyboyHPD is offline   Reply With Quote
Old 08-16-2016, 09:09 AM   #3
Coachwork: Gillig
Thank you for your insight! I'm definitely painting our roof white as well.
Old 08-16-2016, 10:57 AM   #4
Id love to get ahold of tinted windows that would fit my bus!!. i would jump on those in a heartbeat!..
Old 08-16-2016, 11:13 AM   #5
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
i got 11 of my windows limo tinted, for $230 i took them all out to take in nobody can see in and the heat droped tramedously inside but i still have 5 more windows to tint. the four in the rear and a small side window up front. but i have a short bus.
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 08-18-2016, 11:01 PM   #6
Coachwork: Gillig
What is your recommendation for a GOOD white insulating paint? I'd like it to last
Old 08-19-2016, 05:39 AM   #7
FlyboyHPD's Avatar
I believe there are a couple of companies out there that have a similar product but this is the company I'm going to go with. They have good reviews.
They have two products. Insulating ceramic beads that you can mix into your own paint, and then a product called "BusKote" that is an elastomeric rubberized paint that has the insulating beads already mixed in.
Insulating Paint | Insulating Ceramic Paint Additive | Official NASA Spinoff
Old 08-19-2016, 06:34 AM   #8
Coachwork: Gillig
Checking out that buskote. Sounds great! Do you know if you need any prep other than sanding your roof?
Old 08-19-2016, 06:49 AM   #9
FlyboyHPD's Avatar
I would sand the roof and then wipe it down with acetone to make sure it's good and clean before putting down the paint. Then just roll it on. I'd go with 2-3 coats for proper coverage.
Old 08-19-2016, 09:06 PM   #10
Coachwork: Gillig
Awesome. Thanks.
bus, replacement windows, tinted windows
