Old 07-15-2011, 01:37 AM   #11
Chassis: chevrolet
Engine: 292L 6
Re: Screens
Small stainless leaf springs; like in a barret.
oldschool is offline   Reply With Quote
Old 07-15-2011, 07:47 AM   #12
lornaschinske's Avatar
Rated Cap: 89
Re: Screens
How about the turn buttons they use to hold screens in window frames? And why are you wanting to use wood? They sell aluminum screen track and plastic corners in Lowes/Home Depot. Just straight cut with a hacksaw, stick the corners in and add fiberglass screen/spline. Easy and fast. That's what I used to make our screens. Make the frame slightly bigger than the opening so that the screen frame sits on the hatch frame and use the turn buttons to hold it tight to the hatch frame. The curve of the roof should be a big deal since the aluminum screen frame will flex a little and the turn buttons will hold it tight. Just make sure you get turn buttons sized for the thickness of your screen frame. Also easy to remove and clean.
Turn button (back spacer was trimmed so the button sits flush on the window frame)
Fulltime since 2006
Old 07-15-2011, 10:06 AM   #13
opus's Avatar
Chassis: All-American R/E
Re: Screens
I could do that but there is no stores like that for 120 miles. Wood is more readily available [in the shop] and a lot cheaper.
Window Screens for Bus sportyrick Conversion General Discussions 6 09-25-2010 07:03 PM
Window Screens TygerCub Conversion General Discussions 3 06-14-2009 08:35 PM
window screens ezbme Conversion Tutorials and How-to's 1 05-16-2009 01:55 PM
Window Screens nyrockingchairs Conversion General Discussions 13 08-22-2007 08:55 PM
Windows screens vonslatt Conversion General Discussions 13 08-11-2005 08:35 PM
