Old 12-21-2012, 03:22 PM   #1
Chassis: Blue Bird
Engine: DTA360 Spicer 6+1 Manual
Screws Instead of Rivets?
I will be skinning over all of my windows and it occured to me that some sort of selt taping screw is a whole lot easier to put in than a rivet. Is there any reason not to use screws? Will they shear with the bus twist? How about screws with gaskets on them?
I am pretty sure everyone is going to say they will shear and I wonder how likely this is.... After all most people build out there whole interior with screws..
Thanks In Advance
Tony
rex_1_mn is offline   Reply With Quote
Old 12-21-2012, 08:11 PM   #2
bapos's Avatar
Chassis: 2001 International RE
Re: Screws Instead of Rivets?
From someone that is in the middle of doing this... I can testify that rivets have been a good choice. The prior owner did some of the sheetmetal work and obviously use a hand tool to clamp them together. I am using a air pneumatic and its REALLY tightened them up.
The only down sides I see to self tappers is....
1) The will stand out from the sheet metal. Not the best look in the world but hey if you ok with it then roll on.
2) I would think over time they would vibrate loose? maybe Im wrong but food for though
3) I would be worried abotu them shearing as you described.
I havent looked at the price comparison but I dont think it would be a huge difference. Im sure they will work.
Hope this helps
Old 12-21-2012, 08:23 PM   #3
if you will notice, some busses like mine have both metal screws and rivets. Since mine is a 1991 model, the screws have not become unscrewed, however, they are not self-tapping, which i have found, sometimes will loosen, and i don't think they hold the same tensile strength as the normal large sheet metal screws. but thats fwiw.
That being said, i have used rivets, sheet metal screws, a few self-tapping screws as well as the smaller size lag bolts to hold the panel that covers up the window areas in my bus. I have driven my bus approximately 5000 miles, and there is nothing that has loosened over the past couple of years. I also have the flange and roof cap for my wood stove screwed down with several self-tapping screws, and none of them have loosened either.. even at 70 mph.
so that is my experience.
Old 12-22-2012, 10:23 AM   #4
browncrown's Avatar
Rated Cap: 79 at Birth
I used the self tapping screws on my window skins and also on the roof to hold down the solar panels. So far, everything seems to be o.k. The exterior body of the bus is all rivets and the old Gulmite type of screws that Crown used. I have put about 15,000 miles on the bus since I have owned it.
BC
Self taping screws in roof Gearhead94 Conversion Tutorials and How-to's 1 11-07-2012 04:33 PM
rivets vs self tapping screws chev49 Skoolie Conversion Projects 15 07-25-2012 06:26 PM
Screws for floor BUSBOZO Conversion General Discussions 11 12-13-2009 01:44 PM
Window Screws TheHokieHoopty Conversion General Discussions 3 10-25-2005 02:31 PM
Getting big screws and nasty screws out AARRGGHH!! Branden Conversion General Discussions 7 06-19-2005 08:27 PM
