Old 04-24-2015, 10:26 AM   #21
Chassis: Blue Bird
Engine: ISC 8.3
You were right the first time. Denatured and rubbing are different alcohols (ethanol vs propanol). The former is the "active ingredient" in your beer. When sold as denatured, it has other additives blended in to make it highly unsuitable for human consumption -- thus "denatured."
But anyway, even though they're different, both should work equally well for prepping the surface for silicone.
Old 04-24-2015, 12:06 PM   #22
Chassis: MVP
Engine: CAT 3116
Good to know. I guess I'm only a partial dumbass...
Piersg is offline   Reply With Quote
Old 05-03-2015, 08:04 AM   #23
On a slightly different use,
I plan to remove a number of windows from the sides of my bus ... and replace them with a sheet of mild steel (16 or 18 guage), insulate the hole, and cover the blank space in the interior with what ever material I will install on the walls.
To save time and work, I might like to glue and rivet in the steel. I would like this to be a permanent modification.
What type of panel adhesive might work in this situation?
Tedd is offline   Reply With Quote
Old 05-03-2015, 09:05 AM   #24
Engine: 190hp 5.9 Cummins
Por 15 paint is listed as a steel adhesive.
3M makes a two sided tape specifically for this purpose. A guy on pirate 4x4 built a hard sided off road camper using only this tape, no mechanical fasteners. He uses it in Australia where the heat is extreme.
Old 05-03-2015, 09:12 AM   #25
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I've used 3M VHB double sided tape on a couple of panels on my bus (one of them shown here) that's held up through a South Jersey summer (hot and humid) and winter and has yet to let go. I plan to continue to use it for the windows I plan to pull and sheet over.
Old 05-03-2015, 02:23 PM   #26
What kind of water resistance does that tape have?
taskswap is offline   Reply With Quote
Old 05-03-2015, 02:28 PM   #27
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
I wouldn't build a boat with it, but as long as the two pieces are dry when applying, it doesn't come off. And so far, I've seen no leaks with it yet.
Old 05-03-2015, 03:42 PM   #28
This sounds like what I'm looking for.
Throw in some rivets, maybe some sealant on the seam ... insulate and install the interior walls.
Maybe 3M should change the name of this product to Window-Be-Gone.
Thanks!
Old 05-04-2015, 05:41 AM   #29
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Thanks!
I wouldn't even bother with rivets. Tape, seal, insulate and install. As Nat posted earlier, if a guy in Oz can build an offroad camper with VHB and no mechanical fasteners, then window replacement should be no problem as well.
