What an excellent question. That subject seems to come up a lot.
Some people weld patches and screw holes, other's epoxy pennies over the holes after the floor has been treated and painted. Other's put flat head bolts in the holes.
It doesn't matter that much what you use to cover or fill the holes. The floor insulation will mold around any lumps in the floor.
There is talk about a possible metalurgical reaction between the primarily zinc pennies and the steel floor.
You may need to touch up any exposed metal edges around the screw holes from underneath.
You're making pretty good progress.
Thanks for the suggestions, I've been obsessed with getting to work on a bus for years. Now that I have when I'm going gung ho!!!
