Old 06-20-2007, 11:04 AM   #1
Re: Seat removal - best method?
I just went through that process. My bolts were very rusted and some broke off while trying to remove them so I basically finished the job with a grinder. I had a fire extinguisher at hand, and wore safety goggles
After removing the seats, i drive the remainder of the bolts out from the top with a punch, and sealed the holes with caulking.
Rick
RichardRWatson is offline   Reply With Quote
Old 06-20-2007, 04:02 PM   #2
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
A grinder is probably the most common way of getting them out if a socket won't do it for you.
Firearm is offline   Reply With Quote
Old 06-20-2007, 05:43 PM   #3
oldog12's Avatar
I tried an air chisel, drill, socket/vise grips and finally a grinder.... Grinder works best... Wear goggles and a respirator, I think the dust and other stuff from the grinder is, well, nasty....
oldog12 is offline   Reply With Quote
Old 06-20-2007, 08:27 PM   #4
GoneCamping's Avatar
I also tried many methods, and found the angle grinder to work the best and fastest. There is one guy over at another bus board that insists using a maul head and a sledge hammer works, but the few I tried that with just bent the floor up a little.
I'll also ditto the safety glasses, a pair of gloves as those sparks fly everywhere...and I didn't have a respirator, but I did use a surgical mask as the crud, smoke and burnt rubber will turn your nostrils black!! (I learned that the hard way)
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 06-20-2007, 08:40 PM   #5
the_experience03's Avatar
http://havoconthehighway.com/IM000501.MPG
Protective clothing is over rated. All those sparks help keep you warm when you're grinding in February. Mmm...just to listen to that bus purr is glorious.
Old 06-22-2007, 10:43 AM   #6
frank-id's Avatar
Re: Seat removal...... FIRE
I just purchased a Blue Bird bus. The rear seats were a reasonable task. My sweetheart on the inside and me under the bus. After about 6 seats, different method. I used a acetylene/oxygen cutting torch. My wife's chore was to cool anything on fire and the seat legs, with a garden sprayer filled with water. The job was very quick and painless. Nothing caught fire. The seats were mounted to a bus side wall and the fasteners were easy to remove after the seat bottoms were removed. The leg bolts thru the floor were 5/16 inch diameter and cut very quickly with the torch. Total time to remove seats and throw out the rear was less than 2 hours. My wife is the perfect helper. I'm gonna modify some seats by cutting off some legs and welding to others so as to allow seats to free stand on the shop floor. No one seems to want school bus seats. Frank
Old 06-22-2007, 11:20 AM   #7
oldog12's Avatar
Originally Posted by frank-id
I No one seems to want school bus seats. Frank
... Ain't THAT the truth
Old 07-04-2007, 09:16 AM   #8
My small town has a community cleanup day once a year where they supply roll-off dumpsters all day long for free. I just piled the seats up behind the garage until clean up day and then tossed them all for free.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 07-10-2007, 04:49 PM   #9
KC10Chief's Avatar
Rated Cap: 60
I would NOT use an O/A torch just to get your seats out. Sounds like a great way to burn your bus to the ground. If your international is anything like mine, the bolts go all the way through the floor and there's a nut underneath the floor outside the bus. So, you'd have to have two people to get them out. But I just bought a nice little Dewalt angle grinder and made quick work of it. Using an angle grinder makes you feel like a man anyways. But definately wear eye, hand and ear protection. Angle grinders on old seat bolts are LOUD!!!
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
https://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 07-10-2007, 09:31 PM   #10
bus-bro's Avatar
Engine: 3208 na boat anchor
Don't know what all the fuuss is about.
I used 4 "vise grips" from harbor frieght, and me down below on a ratchet wrench. A 78 passenger skoolie = 1 man day.
Old 04-17-2021, 11:35 AM   #11
A_Bus_Called_Quest's Avatar
Engine: DT466 / MD3060
Jumping into an old thread with new confirmation - This is the way!
Harbor Freight vice grips (the price is right) and an impact driver or good ol' socket wrench.
I used the vice grips underneath, and pulled the bolts from inside the bus. 15 seats took me about an hour.
Thank you all for the good suggestion!
A_Bus_Called_Quest is offline   Reply With Quote
caulk removal butcher_boy Conversion General Discussions 6 04-09-2019 10:46 PM
What's your preferred heating method? Looking for insight. enthe0gen Heating, Cooling and Appliances 19 01-25-2014 05:01 PM
What type of jack/method do you use? heathnlaura Conversion General Discussions 9 06-26-2013 03:04 PM
Seat removal tip if you don't have a helper Butnerbus Short-Bus Conversion Projects 9 02-04-2013 10:41 AM
seat removal Jody Conversion General Discussions 3 04-18-2006 07:59 PM
