Closed Thread
Old 09-15-2015, 12:18 PM   #21
Chassis: TC2000 RE
Engine: 8.3l Cummins
But now it's not secret anymore, you need a new spot!ARRGH
Originally Posted by The-Breeze View Post
Our secret compartment is located behind the "entertainment center"
aaronsb is offline
Old 09-15-2015, 04:04 PM   #22
Nobody reads this forum i don't know what you are talking about.
CaptainInsaneo is offline
Old 09-15-2015, 08:13 PM   #23
Actually aaron, have you already forgotten "without pictures it didn't happen"
as promised>>>>>
These are pictures of the entertainment center that I discussed in my last post.
I lost the picture I took of the front somewhere in my PC or on Photobucket. When it shows up I'll post it
[/URL][/IMG]
This shows some of the recycled wood I saved from our antique wardrobe. I sanded it down (without a mask inside the bus....landed me in the ER a few days later) Note to self...wear mask & do all sanding outside. I applied about 3 coats of poly with light sanding in between may add more layers once I can find the top again LOL
[/URL][/IMG]
This is the tall narrow cabinet that I measured and saw that the empty space on the wheel well cover was just waiting for me to cut in half & install. I took one half & faced it towards the front of the cabinet & the other half facing the side. This is showing how it is removable & easy to take out.
[/URL][/IMG]
This shows it completely out & the deep absyss now available to fill up with some very special "stuffs" that we just know has to come with us on our journey
[/URL][/IMG]
The-Breeze is offline
Old 09-16-2015, 12:11 AM   #24
cleaver, I see what you did there.
Old 09-17-2015, 10:21 PM   #25
USMCRockinRV's Avatar
Chassis: Safe-T Liner MVP
Engine: 12V Cummins
Rated Cap: 75
This is the Single aft Couch Arm I built with a secret box for my Pistole...Click image for larger version
ID:	8585Click image for larger version
Thomas
Safety Liner MVP
USMCRockinRV is offline
Old 09-17-2015, 11:46 PM   #26
Engine: 190hp 5.9 Cummins
Sick man.
nat_ster is offline
Old 09-18-2015, 12:07 AM   #27
Nice couch hidey spot.
Although the finger hole and topside hinges are a dead give away something is below it. I am guessing you leave a tv guide or something easily tossed away on top of it.
One thing I know to be true, if something is hard to use/ access, no matter how well it does its job, you won't use it.
Old 10-28-2015, 01:18 PM   #28
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
When taking up the old plywood floor in my daughter's E350 based bus, I found out there is a fully formed low spot on the passenger's side, right where your typical van side door would go. It's a perfect little spot to create a hidey hole I think.
Puggy is offline
Old 10-28-2015, 03:06 PM   #29
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
what a great thread. as i need my secret spots as well.
BurlKing is offline
Old 11-02-2015, 01:44 AM   #30
My dad taught me long ago that cops can do what ever they want. you can refuse the search and they will find a reason to search you anyways. Any cop with half a brain will know at least a dozen legal loop holes or ways of legally searching your rig. The difference might be if they tear your rig up in the process. As for secret compartments... the easiest would be to hide the opening in the trim work. I have a master bedroom set with tons of secret compartments. i never even knew until the salesman started opening them all up. Most modern furniture has a pretty outer shell with draws but often times it has lots of dead space between or on the sides of draws. You just have to make it so the trim piece between the upper and lower draw will open or the side trim piece next to the draw. even a 2" X 5" X 10" compartment is enough space to hide a gun, cash, etc.....
Kipin is offline
Old 11-02-2015, 02:41 AM   #31
True, but not say a completely hypothetical AK-47 or AR15.
Old 11-06-2015, 07:48 AM   #32
Tinyhousebus's Avatar
I was thinking of building a hollow side wall as part of a floor to ceiling cabinet for storing long guns if that makes sense. So the left side of the open cabinet/shelves would stick out a couple inches and be hollow. Then maybe a bolt attached to the exterior panel that goes through the interior cabinet panel held with a wingnut. That way there wouldn't be any visible latches and the panel would be flush to the cabinet
The Tiny House Bus Build
Tinyhousebus is offline
Old 11-06-2015, 09:45 AM   #33
I won't have any guns on board due to regulations and international border crossings.
I will have pneumatic cannons that launch pieces of wood, metal, ect.
Once they are taken apart, they look like nothing but a pile of parts.
nat_ster is offline
Old 11-06-2015, 08:38 PM   #34
I like to have a friend along just in case, or, as in this case, in a case---along with my array of permits[/URL][/IMG]
[/URL][/IMG]
ol trunt is offline
Old 11-06-2015, 11:45 PM   #35
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I gave up on trying to hide my stuff so I will mount it on the roof.
I'm hungry!
You Gotta Let Me Fly
crazycal is offline
Old 11-07-2015, 10:24 AM   #36
That's what I'm taking about.
I like that way better.
In the video's, they blow both doors right off that mini van. One gets pushed right through the van.
It's amazing the energy a 10 pound pumpkin can deliver compared to a tiny little 9mm round out of a handgun.
Guns are way over rated any way. Up close a sward or machete is far more lethal, and won't run out of ammo.
For most, guns are a false sense of security.
This is coming from someone that grew up with using long guns everyday, spent 4.5 years in the Canadian Military, and has spent time protecting drill rigs with deadly force over seas.
nat_ster is offline
Old 11-07-2015, 10:42 AM   #37
Quick! To the ramparts! Start tossing the pun'kins before the trick-or-treaters storm the fortress!
Yup, that 'ill work every time--what were we thinking?
ol trunt is offline
Old 11-07-2015, 10:59 AM   #38
Fill the pumpkins with explosives and a impact detonator.
nat_ster is offline
Old 11-07-2015, 12:24 PM   #39
Moderator
crazycal's Avatar
Trunt, is that a CZ? Too much shadow in my picture.
I'm hungry!
crazycal is offline
Old 11-07-2015, 02:51 PM   #40
CC. Sig 226 non-slide 9mm. It looks a little funny in the pic because it has a foam dust plug in the barrel.
ol trunt is offline
Closed Thread
