Old 05-26-2019, 11:40 AM   #21
HazMatt's Avatar
Chassis: IH 3800, 8 window
Originally Posted by Sleddgracer View Post
certainly ready to learn from your mistakes, problems and successes
And that is precisely the sequence of events on this project! Save the last...
Still a work in progress. [emoji6]
Old 05-26-2019, 12:08 PM   #22
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
my goal, once I find my bus, is to make a comfortable unit, reasonably attractive, and very practical for my needs, using methods that will allow me to complete the conversion while I can still use it - lol
Old 05-26-2019, 12:24 PM   #23
HazMatt's Avatar
OMG! Don't try this at (Tiny) Home, kids!!!
I conscripted my bus as The Kwik-Exit Moving Company, to get the frell outta Dodge.
All mods are taking place while I am in residence.
This whole evolution would go multiple orders of magnitude more quickly; if I didn't have to keep relocating crap, working around my built-ins, going extra steps to minimize metal shavings contamination, et al.
'Course, you have a home base for all of your stuff, so you needn't have a diesel blivet like me...
Old 05-26-2019, 12:48 PM   #24
Okay, we can close this thread. You all come up with some amazing solution, none of which fit my criteria. Once the WHOLE ceiling is glued I imagine it will have as much or close to the strength it had before. I don't think there is enough flex in a bus to pull it all apart. My plan was to widen the groove on the first piece going up against the underlayment and tucking the underlayment into the groove. But both boards are 1/4" thick, so I will remove the bottom of the groove edge, overlap it on the underlayment. I'm going to go ahead and glue up a sample and see how hard it is to pull off after curing.
What I'm seeing is no one has done it so it's all speculation.
Old 05-26-2019, 12:59 PM   #25
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
OMG! Don't try this at (Tiny) Home, kids!!!I conscripted my bus as The Kwik-Exit Moving Company, to get the frell outta Dodge.
I'll be able to park my bus 25' from my house, and 15' from my workshop, so that should help - I don't envy you living in the construction zone, or those that have to drive to where their bus is parked, or worse yet, having to rent a space to work on their bus - I have virtually no worries about vandalism with my mobile security team in place, plus living so far off the road -
Old 05-26-2019, 01:10 PM   #26
I had 3 construction adhesives to choose from, so was going to do 3 separate boards to see which worked best. I put the first one up, Dynaflex Ultra. Started to glue up the second one and the first one fell down, so much for grabbing ability, stuck it back up there. Proceeded to stick the second one up, Loctite Power Grab HD, 0 second instant grab, seemed to work. The first one fell down again. That's when I realized it isn't adhesive, it's sealer caulk, duh.
The 3rd one went up with Loctite PL Max Premium. I'll hang from both tomorrow and see if they hold my weight (162, down from 21
Old 05-26-2019, 01:14 PM   #27
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
l'll be watching to see which glue holds best - now you know that caulking doesn't work the same as glue - lol
Old 05-26-2019, 01:33 PM   #28
I knew that before, just didn't read the label to know it wasn't adhesive.
I'm guessing I won't know which holds better as they will both probably hold my weight.
Old 05-26-2019, 02:44 PM   #29
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
if either one will hold your weight, then either one would hold an 1/8" thick panel in place I would think
Old 05-26-2019, 02:56 PM   #30
HazMatt's Avatar
Nice! That setup will make things considerably easier.
My commute isn't at all painful- open my eyes in the AM, & I'm there...
"Mobile Security Team," LOVE it!
ROFL Yet another tragic tale of caulk self-abuse!
Can you wedge the planks against their sealing surface using C-clamps against the hat-channels?
Old 05-26-2019, 02:56 PM   #31
1/4", but all it needs to do is hold them in place.
Old 05-26-2019, 03:04 PM   #32
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
"Can you wedge the planks against their sealing surface using C-clamps against the hat-channels?"
good idea - with a bit of a modification, that idea might just work fine - using a 2x4 to wedge the panel up, and C clamp the 2x4 to the hat channel should keep the panel damage free
Old 05-26-2019, 03:07 PM   #33
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
I'm thinking of 1/8" thick pre-finished paneling with one of the photo finishes they offer
Old 05-26-2019, 03:29 PM   #34
I looked at birch 1/4" ply, $45, then saw this 1/4" underlayment and thought it would be like crappy OSB or something. It actually can be used as a finished surface. The grain pattern is good and has unique Pine Beetle bore holes that effected the color around the bore hole, then each perfect 3/16" bore hole was filled with light colored filler. I think it has lots of character. $14/sheet. Think it will take stain nicely also.
20190526_161626.jpg   20190526_161634.jpg   20190526_161657.jpg   20190526_161718.jpg
Old 05-26-2019, 03:31 PM   #35
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
very nice find ! - it is going to take a fair bit of sanding to get rid of the cross hatch marks - they'll grab all the attention when finished with a clear stain
Old 05-26-2019, 03:33 PM   #36
2.5 hours after putting these 2 test pieces up. I'm good with either LocTite product for this application. Now I get the sawzall to cut those samples down.
Here's 100lbs hanging from them.
Old 05-26-2019, 03:39 PM   #37
very nice flooring bro! looks sharp as a tack
superbusWI is offline   Reply With Quote
Old 05-26-2019, 03:42 PM   #38
HazMatt's Avatar
Like a homely broad, it has LOTSA character!
Dissimilarly, you might want to run to moderately coarse sandpaper, to knock down the mill marks before finishing the sheets.
Is that going over the wall/ceiling curve? 1/8" plywood is plenty bitch-kitty to fit. Kerfs, maybe 1/4" spacing, might make it go. More easily, anyhoo...
What will that poor child do after being cut off at the wrists..?
Old 05-26-2019, 03:52 PM   #39
The 1/4" ply will span the center section of the ceiling down the 2 fore and aft rails, the boards will start from that rail and continue down the ceiling to the tops of the windows.
Here's my 165lbs hanging.
Old 05-26-2019, 03:54 PM   #40
I have made curved "T" braces to push the ply against the ceiling while it sets. Don't think I'll need anything to hold the boards other than the 0 second grip adhesive. Gotta run the electric in the garage tomorrow and then panel the ceiling.
