Old 05-26-2019, 04:47 PM   #41
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
2.5 hours after putting these 2 test pieces up. I'm good with either LocTite product for this application. Now I get the sawzall to cut those samples down.
Here's 100lbs hanging from them.
that's impressive
Old 05-26-2019, 04:55 PM   #42
Originally Posted by Sleddgracer View Post
that's impressive
I just went out and whacked with a hammer and they came off easily, but they hold the weight and I'm good with it.
Need to start wiring and was pleasantly surprised to see a hole through the fore/aft ribs in every single section to run wires through, I had planned on drilling my own.
Old 05-27-2019, 01:15 AM   #43
Quite handy, Remember the grommets!
Nice work on the experiment! I just LOVE a little scientific process.
Old 06-01-2019, 07:26 PM   #44
i had a customer request that i glue all the sheetrock up in a room, same reason as you, no fasteners to tape over=less work. I like your idea, glue the wood on the metal ribs, I think I'd go at it with PL 3X construction adhesive and poles to gently press the boards in place. Try to not press too firmly so as to glue starve the joint, but just firmly enough.
motorsoup is offline   Reply With Quote
Old 06-01-2019, 08:21 PM   #45
I made a few "T" braces in the profile of a ceiling rib the exact length floor to rib. They should work perfect on the 1/4" panels going up.
Old 06-01-2019, 08:57 PM   #46
Year: 2005
Jeez, you could build a 12" Stonehenge with those!
Artor is offline   Reply With Quote
Old 06-03-2019, 02:22 PM   #47
Year: 93
Coachwork: Corbiel
Rated Cap: 36 pass
Keep some tape and or shims handy to get them braces just right for height, you may find a little variance.
Free Bird is offline   Reply With Quote
Old 06-03-2019, 02:33 PM   #48
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
I'm planning on using some underlayment in 1/4" down the center of the bus and then 1/4" T&G boards from there down. Would I be making a mistake gluing these boards and panels. I don't want a bunch of fasteners showing.
Thomas glues the steel roof panels to the ribs now with industrial aircraft adhesive. I think you'll be fine on the interior. Just get the good stuff.
CMORGANSKOOL is offline   Reply With Quote
Old 06-03-2019, 06:53 PM   #49
What part of they fit perfectly was hard to understand?
Old 06-03-2019, 09:48 PM   #50
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Mark,
Are you using all rigid foam for your insulation. Just curious. I'm finding it hard to get a spray foam contractor to commit.
peakbus is offline   Reply With Quote
Old 06-03-2019, 10:18 PM   #51
Originally Posted by peakbus View Post
Mark,
Yes, I keep getting to points where I say okay, now I'll spray the rest. But things change so much that I'm avoiding the "permanence" of spray foam. Doing a piece of 1/2" first followed by a tightly fitting 1" piece seems to take the curve. I will use cans of closed cell to fill in once everything is kosher.
Old 06-03-2019, 10:22 PM   #52
wrong thread
Old 06-03-2019, 10:38 PM   #53
https://youtu.be/jrmZIgVoQw4
