Old 09-21-2010, 04:20 PM   #1
opus's Avatar
Chassis: All-American R/E
Securing things to a floating floor
How do you go about it? Just screw it all to the plywood? Couches/chairs in particular. Obviously bunks and cabinets can go to the ceiling or a wall.
Old 09-21-2010, 04:52 PM   #2
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
Re: Securing things to a floating floor
Hey Opus ..
.. I have to be honest with you man .. some of the installations I have seen scare me to death .. floating floors and minimally-secured hardware inside the bus with warm bodies is not good in an emergency .. if you absolutely must have anything inside, bolt it all down .. tight .. through the floor so that nothing flies apart in a fender bender or , God forbid, a roll-over ..
.. I used to have some pictures of the back end of an ambulance that flipped over, didn't roll, just flipped after impact .. the O2 tank destroyed everything in the rear, including the paramedic's career, and only made an already injured person worse-off .. the defibrillator punched a hole clean through the wall and the rest of all the flying gear became shrapnel .. for what it's worth, bolt it all down .. hard .. put your batteries and water tanks, and every other accessory you can, under the bus and mounted to the frame .. even a gameboy/Nitendo DS can do some damage at 40+ mph, much less the TV it is attached to .. just saying ..
God's Speed brother ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 09-21-2010, 05:11 PM   #3
opus's Avatar
I just spent a week in an entertainer coach. The only saving grace there is the wall at the front to keep from killing the driver or launching everything out the front window. I'll have to look at this more.....
Thanks Bill
Old 09-21-2010, 11:32 PM   #4
lornaschinske's Avatar
Rated Cap: 89
I'm rather fond of the "bolt the suckers to the floor" theory. Along with locking all the cabinet doors/drawers shut and pinning the fridge & freezer doors shut. I would rather my "cause of death" isn't listed as a flying pickle jar!
Fulltime since 2006
Floating floor squeaks? TygerCub Conversion General Discussions 29 06-23-2019 07:46 PM
securing a roof deck TygerCub Conversion General Discussions 11 08-05-2012 10:10 PM
Securing cabinet doors? Diesel Dan Conversion General Discussions 7 11-15-2011 06:41 PM
securing folding doors starbus Skoolie Conversion Projects 11 01-23-2010 09:14 PM
Floor: Floating or not? John Conversion General Discussions 2 08-06-2008 07:51 AM
