Old 08-14-2013, 06:25 PM   #1
Engine: Int. DT466
Rated Cap: 35
Seeking sealant advice
I have some holes in my roof as well as some seams and pop rivet holes (from raising my roof) that need to be sealed.
I need to do seal and then paint over. I'm going to be using miller equiptment enamel paint. I'm looking for suggestions, testimonials, ect, on the most burly sealant I can afford.
Thanks in advance for any advice!
kyletheyeti is offline   Reply With Quote
Old 08-21-2013, 07:04 PM   #2
Engine: 190hp 5.9 Cummins
Re: Seeking sealant advice
Automotive seam sealer. Never fully hardens, and takes paint, heat, ect.
Next choice would be some good kitchen and bath, or Automotive silicone. Wipe down surfaces with 99% isopropyl rubbing alcohol, before calking. May or may not take paint.
Old 08-21-2013, 09:21 PM   #3
Chassis: B3800 Short bus
I've been using Supra Expert for sealing up my exterior. Works great! I tried GE's Silicone II as well, but I liked Supra better. It seems closer to the original caulking on the bus. Also, it comes in an arse load of colours and can be painted.
http://www.mulco.ca/en/industriel/pr...uits_c_ext.htm
Most hardware/lumber stores have the stuff in stock in Ontario. Not sure about the rest of the country or the USA...
Old 05-29-2015, 01:58 PM   #4
Year: 1982
Coachwork: Ward
I decided to break the bank and put Avueco Seam Sealer on the roof seams 6 tubes ordered by Mill Supply
https://www.millsupply.com/auveco-au...01.php?p=52479
Then Eternabond 2 inch tape. ordered by Big Rock supply
https://www.bigrocksupply.com/store/...n-x-50-ft.aspx
https://www.bigrocksupply.com/store/p/5847-EternaBond-RoofSeal-White-2-in-x-50-ft.aspx"]https://www.bigrocksupply.com/store/p/5847-EternaBond-RoofSeal-White-2-in-x-50-ft.aspx
[/URL]Will cost $150 all said and done
Still deciding on which paint for the roof.
Snow roof - premium 12 year warranty (2 coats, 5 gallons - $120)
Henry - many different options - the company says to go 100% silicon - HE887HS silicone roof coating and sealant $250 Home Depot product
of just another coat of Aluminized Roof Paint (I did a coat of this 18 years ago)
starbillie is offline   Reply With Quote
Roof Pannel Sealant oldog12 Conversion General Discussions 7 05-29-2015 02:31 PM
Seeking Colorado Skoolie The Kents Classifieds | Buy, Sell, Swap 1 07-24-2010 09:18 PM
seeking someone to hire to build my bus puddin1315 Classifieds | Buy, Sell, Swap 8 12-07-2008 02:04 PM
What's a good sealant for roof vents? KC10Chief Conversion General Discussions 0 03-26-2007 11:55 AM
Seeking advice about buying a bus PunkAssKidBC Alternative Fuels | Electric, Propane, Wood Gasification, etc. 2 01-17-2007 10:02 PM
