Old 05-05-2017, 08:03 PM   #1
Coachwork: Girardin Minibus IV
Chassis: Ford E-450
Engine: 7.3L Diesel
Rated Cap: 22
Sheep's wood insulation in a fiberglass bus... questions!
Hey y'all,
Finally ripped off the last of our ceiling panels and tore out the last of the insulation. Our bus body is FIBERGLASS so there was minimal rust (with the exception of a few metal bars which we repaired or replaced). Next steps!
I want to use sheep's wool for various reasons (non-toxic, sound deadening, sustainable) and will have a 1/4" plywood and cork flooring on top of that. My question is... do I need to include a vapor barrier? The metal ribs will be coated with flex seal/rubberized sealant.... fiberglass doesn't rust... wool will hold water but increase in R value... cork is mold and water resistant. Should there be a vapor barrier to protect the sheep's wool or does it not matter since fiberglass doesn't rust and cork is water/mold resistant.
PLEASE HELP!!!
Sent from my iPad using Tapatalk
SunnyLordh is offline   Reply With Quote
Old 05-05-2017, 08:24 PM   #2
Robin97396's Avatar
For longevity I'd skip the organics in the floor. You can't avoid spills and humidity.
Robin
Nobody's Business
Old 05-05-2017, 09:47 PM   #3
ANY organic insulation you use is eventually going to get nasty and moldy.
Old 05-21-2017, 01:25 PM   #4
Have you found a wool insulation source SunnyLordh? I'm really interested in going this route as well. Would love to hear what
you've found / how it's going, if you're willing to share.
Sent from my ONE A2005 using Tapatalk
ayva_c is offline   Reply With Quote
Old 05-21-2017, 01:45 PM   #5
Robin97396's Avatar
Here's some information;
https://en.wikipedia.org/wiki/Wool_insulation
Sheep Wool Insulation
Good Shepherd Wool | Wool Insulation
Black Mountain 16" Natural Sheep Wool Insulation - Eco-Building Products
Sheep Wool insulation Black Mountain USA
Oregon Shepherd – Natural Wool Insulation
https://evanandgabbystinyhouse.wordp...ol-insulation/
Thermafleece | The Original Wool Insulation
https://www.builddirect.com/blog/eco...n-sheeps-wool/
Pros and Cons of Sheep Wool Insulation
Pros and Cons of Sheep Wool Insulation - PM on Renewables
https://ntenvironmentalwork.net/2011...ol-insulation/
https://www.thegreenage.co.uk/is-she...tant-to-moths/
The thermal resistance or R-value of sheep's wool batts is about R-3.5 per inch, similar to other fibrous insulation types.
There's a lot of information available. It doesn't make sense to me to use a breathable organic insulation when the purpose is to stop air flow. Am I looking at this wrong?
Robin
Nobody's Business
Old 05-30-2017, 11:46 AM   #6
Sorry for the delay... Thank you soooooo much for all this ! Much appreciated.
Old 05-30-2017, 01:05 PM   #7
Brewerbob's Avatar
So the condensation can dry without molding? I dunno. From having to work with fiberglass insulation I bet it's a hell of a lot better to work with than the standard batting stuff.
Old 05-30-2017, 02:12 PM   #8
Robin97396's Avatar
Agreed, most people would rather handle wool than to handle glass batts. I don't know much about wool, but it is organic. Organic materials break down over time. It must decompose over time since you never hear about antique sweaters.
It seems to be dust accumulation in combination with moisture that allows mold to grow in fiberous insulation. Is wool any different functionally? I'd expect to see the same problems with dust accumulation and possible mold growth over time. Can an organic material work better than glass batts? I'm certainly not impressed with the glass batts.
Buses are plagued with unavoidable moisture or humidity issues unless you live in the desert. Displacing the humid air and sealing off metal surfaces was the goal of my chosen insulating material.
I've certainly made a lot of mistakes while building this bus, but I'll be much better educated for the next bus.
Robin
Nobody's Business
Old 05-30-2017, 02:41 PM   #9
Brewerbob's Avatar
I only know about wool clothing and hiking gear. "Cotton kills" is the phrase. You get cotton wet and the temp drops and you are ROYALLY screwed. Wool keeps 60% of its insulation even when wet. The clothing is anti microbial treated so it takes a week for you to smell like wholesale as$ instead of 3 days. Since you aren't wearing this stuff they could go hogwild on the treating.
As for how long wool takes to break down, is it really an issue? You and I are going to be ready for the nursing home in 30 yrs. Maybe the 20 somethings on here need to build a bus that will last 50 yrs but are they even going to last that long without ripping the bus apart or starting over with a different bus?
Old 05-30-2017, 02:58 PM   #10
Robin97396's Avatar
Hey, this bus is my nursing home. I'd be shocked if I have another 30 years to go, but who knows?
Ok, now I'm going to make yarn from insulation for a nonmicrobial wool sweater. That's right after I learn to card wool and spin it into yarn. Then I just have to learn to knit. Easy peazy.
Robin
Nobody's Business
Old 05-30-2017, 03:25 PM   #11
I'd go with fiberglass over wool, at least fiberglass isn't organic.
Old 05-30-2017, 03:47 PM   #12
Robin97396's Avatar
Thank you, my point exactly.
Robin
Nobody's Business
Old 05-31-2017, 06:51 AM   #13
Brewerbob's Avatar
Sounds like you're going to need closer to the 30. I'll stick with a loom.
You might but you don't strike me as the hippy dippy type. Some people like their water chemical free, range fee, gluten free, and vegan safe.
Old 05-31-2017, 09:14 AM   #14
Robin97396's Avatar
Make it 40 years and I'll knit you a sweater too. I'm going to make yours out of fiberglass.
Robin
Nobody's Business
Old 05-31-2017, 10:48 AM   #15
Its been scientifically proven that using lambs wool for insulation in a bus makes the horn go bleat bleat rather than beep beep.
Old 05-31-2017, 11:15 AM   #16
Brewerbob's Avatar
That alone would sell the gf on it.
Old 05-31-2017, 12:03 PM   #17
I HAVE to eat gluten free that isn't a choice. My immune system goes crazy from wheat, barley or rye.
Old 05-31-2017, 12:05 PM   #18
Brewerbob's Avatar
You can go ahead and ship me all the gluten water you can find then.
I hate all the stupid new labeling.
Old 05-31-2017, 12:10 PM   #19
Robin97396's Avatar
Gluten
I hope that doesn't include beer.
Robin
Nobody's Business
Old 05-31-2017, 12:13 PM   #20
Robin97396's Avatar
Have you ever seen the gluten free bacon? It's absurd what they are labeling as gluten free now. Things that never had any gluten in them in the first place.
Robin
Nobody's Business
