Old 04-01-2019, 01:41 PM   #1
tugboater's Avatar
Chassis: Saf T Liner MVP 11 window 32
Engine: CAT 3126E
sheet metal buying tips?
So I've read enough on here to decide on 18 ga for skinning my windows. The best price I can find for 18 ga. of any type is just about $100 a sheet (4'x10'). I can get 20 ga about 15 bucks cheaper. I've called 8-10 sheet metal suppliers and shops. The main reason it is so high here in AK is because of shipping.
Any insider or experienced tips on how to get best price?
thx! Eric
One...slow...step...at a time.
tugboater is offline   Reply With Quote
Old 04-01-2019, 01:50 PM   #2
I used 18 gauge and I would be reluctant to go any thinner.
Now I don't feel quite as bad about paying $82 a sheet....,
Old 04-01-2019, 01:59 PM   #3
tugboater's Avatar
Engine: CAT 3126E
Yeah...I was toying with 20, but 18 is what I'll do. The price range I'm getting is crazy. Anywhere from $100-150, and there really seems to be no rhyme or reason to the different prices in regard to type (paintlok, cold vs. hot rolled, galvanized). I'm waiting for a couple more quotes, but the paintlok for $100 is probably gonna be the winner.
Old 04-01-2019, 02:35 PM   #4
I used 20g on mine and it is plenty thick and sturdy enough for skinning. I'm paying $75 for a 4 x 10
Old 04-01-2019, 02:56 PM   #5
Sleddgracer's Avatar
Chassis: still looking for my bus
what is the standard thickness of the exterior skin on a bus?
Old 04-01-2019, 03:11 PM   #6
tugboater's Avatar
Engine: CAT 3126E
I can't weigh in on that one sled. I'm going to borrow by buddies calipers tonight to confirm mine. It seems like an odd spec of 19ga. is what lots of folks talk about here, but I've read people use as low as 16 and as high as 26.
Old 04-01-2019, 03:18 PM   #7
shaymcquaid's Avatar
Chassis: 40' MVP-ER
Unless you plan to weld, go with galvanized material.
Unless you prime IMMEDIATELY!
Also, ask the clerk at the metal shop about any pre existing rust. I sourced metal from two different suppliers and ended up with very different materials rust wise.
I used 18 gauge for the sides.
shaymcquaid is offline   Reply With Quote
Old 04-01-2019, 03:46 PM   #8
On an International the skin is .0675", or 16g.
Old 04-01-2019, 04:10 PM   #9
Odd, Marc. All three of my IC's were skinned with 18ga.
I haven't mic'd the skins on my Thomas but they seem pretty thin.
Roll Your Own Build Thread
Old 04-01-2019, 04:20 PM   #10
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
On my 86 Thomas it is an oddball 15-guage.
I would find a local commercial heating and air shop and talk to them about there scraps and price buying what you need through them.
If you get galvanized you have to wipe it down good with vinegar at a minimum or the paint won't stick.
Primer sticks fine after that.
Make friends with your local to you heating and air shop cause they have the tools to cut bend it if need be and probably throw scraps away big enough to cover a window.
These were pieces to fit the window rib frame opening with 1/2" flanges bent in all the way around for screwing/riveting in the opening and sealed. No problems or leaks and galvanized wiped down with vinegar still holding primer.
When the pic was taken it had been about 3-years in and at 7-years still no issues.
Can you drive down and get it for cheaper?
I have done commercial heating since 96 so I have never had to ask/know what a sheet cost. Scraps are a plenty and if I need a sheet I just say hey boss I need a sheet and all I hear? is okay get it we will work it out?
Good luck
