Old 05-10-2008, 12:06 AM   #1
Engine: 5.9l Diesel Cummins
Rated Cap: 20
Sheet metal guage for windows
What thickness are you all using when taking out windows and covering them with sheet metal?
My 1997 Ford / Thomas shorty
5.9l Diesel Cummins w/automatic tranny
Photo's of my bus build
Billsman is offline   Reply With Quote
Old 05-10-2008, 04:28 PM   #2
Re: Sheet metal guage for windows
I am wondering the same thing. Also are you gonna cut out the pieces to fit each window or long sheets?
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 05-10-2008, 04:43 PM   #3
reprobate's Avatar
After we raised the roof, we went back with 20ga. paint-lock. If you are doing one window at a time, I think a lighter gauge would be ok, especially if you are backing it with a plywood or something. I still wouldn't go lighter than a 26ga. doing one at a time and that with a backing.
reprobate is offline   Reply With Quote
Old 05-10-2008, 09:50 PM   #4
swinada's Avatar
I used 18ga and i dont think I would use any thinner just because i dont wanna have the thundereffect driving down the road.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 05-11-2008, 09:54 AM   #5
Rated Cap: 20
Thanks everyone. I'm going to be covering the lower windows on the rear of the bus but keeping the higher ones. I also plan on removing 1-2 windows on each side. I plan on sheet metal, insulation board and then my wall paneling.
Old 05-11-2008, 09:56 AM   #6
Rated Cap: 20
Individual pieces. I also have some rust on the back that I'm going to clean out, bondo up and cover with sheet metal.
Old 05-11-2008, 11:40 PM   #7
swinada's Avatar
If you're adding plywood (or rigid insulation) behind it, I'd use some construction ashesive
WARNING!!!! read the label for your liquid nails if you plan to glue your hard insulation. make sure its the kind that is safe to use on hard insulation otherwise the liquid nails will eat your insulation up. END of WARNING
good luck with your conversion....
Old 05-12-2008, 08:35 PM   #8
swinada's Avatar
Originally Posted by Smitty
There is a specific type for polystyrene. It's what they use to glue it to concrete for foundation insulation. lol....I don't add "be sure & read the directions" because I figure everyone is that intelligent
Smitty
I'm sure everybody is that intelligent, but if you don't know that liquid nails can eat insulation then you don't think about it till it is to late. And how hard is it to use liquid nails? Do you really read the directions in that very small print?
Old 05-13-2008, 01:13 AM   #9
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
its like pouring gas in a styrofoam cup ugh
Old 05-13-2008, 07:07 AM   #10
reprobate's Avatar
Read instructions. Why the hell would I want to do that? I'm a guy. It's against my genetic upbringing.
Searching for sheet metal M1031 Classifieds | Buy, Sell, Swap 1 04-11-2011 04:00 PM
Sheet metal work opus Conversion General Discussions 1 02-02-2011 04:40 PM
Sheet metal and dimples swhite832 Conversion General Discussions 13 02-10-2010 04:25 PM
Sheet metal over windows... staggerlee917 Conversion General Discussions 27 06-08-2009 02:22 PM
Skinning...Sheet metal, where, what and why? Abbott Conversion General Discussions 17 12-09-2007 07:58 AM
