Old 10-19-2018, 01:55 PM   #21
I have sealed the overlapping seems on both sides of my bus and used two tubes of 550.
I am expecting to go through two more on the seams on the front and rear.
http://www.skoolie.net/forums/f11/pn...tml#post293141
Old 10-19-2018, 04:27 PM   #22
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
If you get the stuff on you or anything else and have a chance to wipe it off right then?
The stuff loves plastic. Cheap grocery store bags are plentiful and work good.
If the stuff is left to cure for a little while on your skin then baby oil and a rag will get it off.
Other than that? You have to wear it. Off
Old 10-22-2018, 06:59 AM   #23
Brewerbob's Avatar
Originally Posted by peterbylt View Post
AIM supply had it on hand locally, recently made and the best price.
Peter
389 miles to the nearest location. Think I might need another source.
Old 10-22-2018, 08:12 AM   #24
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Think I used about 8 tubes of 550 on my steel. I did delete and cover all 20 side windows, two door windows and two rear windows
Nick
Old 10-22-2018, 10:30 AM   #25
Brewerbob's Avatar
That sounds more like it (having never done it). I'm also covering the windows.
adhesive, glue, roof raise, sheet metal
