Old 02-03-2016, 08:08 AM   #1
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap: 90
Sheet metal to sheet metal glue/sealant recommendations?
Hi all,
Getting lined out to start buttoning up my roof raise, and need some advice.
As the title says, Im looking for a good glue/sealant for sheet metal to sheet metal use. Sheets are 20 GA galvanized, and will be screwed together every couple inches as well.
I had hoped to use PL premium or the like (polyurethane construction adhesive), but further research indicates it needs at least one side to be porous, as it is cured by moisture. I don't think the middle inch would ever completely cure on a joint with 2" of overlap.
Our mechanic at work suggested 3M body panel adhesive, which is recommended for van bodies and the like, but I have three issues with it:
1. Two part epoxy is a PITA
2. Cost is $40/200ml. Yikes!
3. I worry an epoxy will be brittle and eventually cracked from vibration.
So, what have you had success with?
Jdecker
JDecker is offline   Reply With Quote
Old 02-03-2016, 08:52 AM   #2
Chassis: B3800 Short bus
If you're planning on skipping mechanical fasteners and going an adhesive-only route then you might want to look into 3M VHB tape.
If you're planning on riveting, screwing or bolting the metal together then just get some automotive seam sealer. I actually used a black butyl vapour barrier caulking (Acousti-Seal by LePage) which has the same ingredients as seam sealer, but it's a bit goopier. I tried another brand of vapour barrier caulking which was completely different and unusable.
Old 02-03-2016, 12:48 PM   #3
Contact Sika Corporation for a recommendation. They make some of the most advanced adhesives on the planet and have several lines specifically for metal to metal. A couple are rated stronger than welding or riveting. Most cars, trucks, trains and airplanes today use these types of adhesives in place of mechanical attachment in many situations.
Old 02-04-2016, 04:36 PM   #4
Engine: T444e
Rated Cap: 34
I'd say grab a little mig welder and lay a bead the whole length of it.
SR2K is offline   Reply With Quote
Old 02-04-2016, 05:57 PM   #5
Peasant Racing's Avatar
Chassis: Ford B700
Engine: New Holland 6.6 Diesel
That's what I would do. No worries about it falling apart and given the price of MIG wire it might also be the cheapest method.
www.maritimedragracing.com
Atlantic Canada’s Source for Drag Racing News,
Race Results, Schedules and Track Information.
Peasant Racing is offline   Reply With Quote
Old 02-05-2016, 01:35 AM   #6
Chassis: TC2000 RE
Engine: 8.3l Cummins
I'd go with sikaflex or the vhb tape. Is the original chassis riveted? Try to copy the techniques the factory used to join the panels.
aaronsb is offline   Reply With Quote
Old 02-05-2016, 10:38 AM   #7
Rated Cap: Your mom +1
This, also if he's not an experienced welder, trying to lay a bead on 20 ga sheet is gonna warp and oilcan the piss out of it...
Old 02-05-2016, 10:50 AM   #8
2kool4skool's Avatar
This to That (Glue Advice)
Don, Mary and Spooky the cat.
Old 02-05-2016, 04:47 PM   #9
Jolly Roger's Avatar
Engine: Detroit 8.2
I have been around sheetmetal for a long time and I prefer sonolastic master seal NP-1 if it is for something you might want to take apart and re-use later just seal the seam outside and or inside or you will waste the edges getting it apart. Run a bead between the two pieces and water to wet your fingers or putty knife to spread out what whatever squishes out when you screw/rivet the pieces together and also cover the screws/rivets I like a small bucket of water and to use my finger but to each his own. Every exterior seam on my bus was caulked before painted.
I am only primered and only because of the neighborhood HOA and the county but its in my driveway and I can work on it when I have time. With almost any sealer exposed .try to keep the exposed beads adequate but small because no matter what brand is used the paint on the sealant is going to crack and expose the caulking regardless. Are as suggested you could go more money and get the tape because it will fit your seams and not squish out for the paint to cover.
I do recommend looking at your manufacterer's web site and or calling them to see what was originally used? The panels I took off were because of rust and the sealant was completely dried up and came off with a fingernail or small scraper and no residue left on the panel's so I sealed everything I didn't remove.
I used NP-1 because it was free from the company I worked for (many a partial tube left at the end of the day ) and they bought 20-30 cases at a time and I know what it is like to take something apart with just the way it was used in my work much less the stuff I have used it for personally. Temporary fixes that worked and had to get back to the pieces? Sonolastic has been around as long as sikaflex and both probably owned by the main provider for all BASF the chemical company.
Old 02-05-2016, 04:52 PM   #10
This is very good info. and from a person that actually knows and has made a living doing this, not from some self proclaimed expert.
adhesive, glue, roof raise, sheet metal
