Old 11-13-2012, 09:01 PM   #1
Chassis: Frieghtliner
sheeting
I am going to sheet over 4 or 5 windows on my bus. I was wondering how to seal the entire sheet to the bus with no leaks? Do I weld it all around, rivet it, combination with bondo/caulking?
Gearhead94 is offline   Reply With Quote
Old 11-13-2012, 09:47 PM   #2
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Re: sheeting
I think any combo of those will work. I dont think Bondo will be an idea choice. I think lots depends on what you have available or what you feel most comfortable with. I am currently riveting the sheet metal on the outside. My sheet is short at the top so Ill be welding in some angle to get it somehting to rivet to at the top. Once the inside sheet metal is off I will start to pack it full of polyiso insulation and then put in the windows.
Old 11-14-2012, 09:04 AM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
Re: sheeting
I think most people use silicone caulk to seal the skin. How you attach it is up to you: rivets, screws, tack-weld, etc.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 11-14-2012, 10:41 AM   #4
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: sheeting
yes, i just removed the windows, cleaned the area with acetone, applied silicone caulk,drilled holes in the appropriate area and attached cut to size 18 ga steel squares to the frames using the window attaching screws
proconsul100 is offline   Reply With Quote
Old 11-14-2012, 11:56 AM   #5
Engine: DTA360
Rated Cap: 16
Re: sheeting
I did a combo of rivets and welding with caulk...
dirtygoat is offline   Reply With Quote
Old 11-14-2012, 07:02 PM   #6
Coachwork: Corbeil
Engine: T444e
Re: sheeting
We used black polyurethane caulk that is meant for roof flashings and for a steel roof, and rivets. It doesn't dry hard so it will not crack if there is any flex.
Alex and Angie is offline   Reply With Quote
Plans for insulation/sheeting floor-What say ye paul iossi Conversion General Discussions 2 01-27-2010 07:49 PM
sheeting windows westport_wayne Conversion General Discussions 6 10-02-2006 10:48 PM
window sheeting westport_wayne Skoolie Conversion Projects 2 04-18-2006 09:26 PM
Aluminum sheeting? Steve Everything Else | General Skoolie Discussions 2 04-28-2004 04:15 AM
