Old 09-22-2006, 07:47 AM   #1
sheeting windows
question to the people who have sheeted up there skoolie windows. what type of sealer have you used ??? silcone- chalking- ???. i want to sheet up a couple of the windows on my bus and just wondered what folks have used. thanks westport-wayne
westport_wayne is offline   Reply With Quote
Old 09-22-2006, 04:05 PM   #2
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
That is what I used over two year ago. Still holding up fine.....
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
Old 09-23-2006, 05:02 PM   #3
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
I used galvanized sheet metal, scewed into 1" plywood cut to fit the opening. Then I screwed the whole thing into place. Before I installed I used clear exterior silicone with butyl tape inside and it sealed great.
-Richard
captainkf is offline   Reply With Quote
Old 09-23-2006, 09:21 PM   #4
Bidin Time's Avatar
Sheeting in the windows
I used butyl rubber in the tube and riveted my .063 aluminum on.
Bidin Time is offline   Reply With Quote
Old 10-01-2006, 02:24 PM   #5
TomCat's Avatar
Year: 1987
Chassis: SaftLiner
Engine: Cat 3208 Turbo 250HP
My Thomas was built out of 20ga cold rolled steel. I used this same material to cover over my windows.
I secured it with rivets on it's front and read edges, screws on it's bottom edge, but used SikaFlex to glue it on everywhere else.
Jay
http://jsbird69.zoto.com/user/lightb...aded-desc/0-90
Jay
87 SaftLiner
TomCat is offline   Reply With Quote
Old 10-02-2006, 12:22 AM   #6
Be careful with silicone it is acidic and can cause corrosion. You are much better off with urethane or butyl.
busone is offline   Reply With Quote
Old 10-02-2006, 09:48 PM   #7
GoneCamping's Avatar
I have been using butyl tape, I get from RV dealers for around $5 per roll...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
sheeting Gearhead94 Conversion General Discussions 5 11-14-2012 06:02 PM
Screening original windows and installing RV windows skoolz out Conversion Tutorials and How-to's 3 10-27-2010 01:54 PM
Plans for insulation/sheeting floor-What say ye paul iossi Conversion General Discussions 2 01-27-2010 06:49 PM
window sheeting westport_wayne Skoolie Conversion Projects 2 04-18-2006 08:26 PM
Aluminum sheeting? Steve Everything Else | General Skoolie Discussions 2 04-28-2004 03:15 AM
