Old 03-12-2019, 07:43 AM   #1
Brewerbob's Avatar
Shopping list...
Has anyone posted an "As Built" shopping list for their skoolie?
Did a quick search of the different sections looking at the stickies and first page of threads. Also did a word search but the search feature sucks.
Not to the inch because every build is different but how much romex did you use? How much pex did you use? How much plywood/paneling? Etc. Some of this stuff is cheaper in bulk. Some of it will be garage sale fodder if you buy too much. 100 feet of wire isn't going to cut it. Will a 250ft roll do? Two 250' rolls?
Doesn't look like Excel is an accepted file type for uploading but pdf is. I have an Excel I started that included every nut, bolt, and washer... then I started slacking. It's still fairly complete but my build it nowhere far enough along to be of much help to anyone else (yet).
