Old 05-05-2009, 10:54 PM   #1
Re: Shore power
OK, lots of choices here.
First, the campground outlets are two basic styles - 30 amp and 50 amp. The 30 amp is one round pin and two angled blades, is 120 volts, and provides (30x120) 3600 watts. The 50 amp is one round pin and 3 parallel flat blades, is 240 volts, and provides 12,000 watts. Most household outlets are 20 amps, maximum, and are usually wired with the common-looking 15-amp outlets. (True 20-amp plugs have one blade turned 90°, and the outlets have one slot and one "T" shaped hole. The different blade styles are to keep people from plugging heavy-duty appliances into light-duty wiring.)
If you are going to be plugging in to houses, etc. keep your load down to 2400 watts, or 20 amps. Use a 12-3 or larger shoreline cord for 20-amp capacity, with a standard 15-amp plug on the business end. For about $5, you can get a hockey puck that plugs into a 30-amp campground outlet, and plug your standard plug in the back. I ditched the 30-amp cord for our lightweight trailer to save weight, installed 20-amp wiring to the "mouse hole," and threw a hockey puck in the cabinet. I usually only plug in in the driveway, but can toss a heavy-duty outdoor extension cord in if I think there will be an opportunity to use it.
The one vanguy67 shows is the complement, the one you want is this one: http://hardware.hardwarestore.com/30...er-668438.aspx
To charge the batteries, you can go with a battery charger, an RV 'converter,' or an inverter/charger all-in-one. A 'converter' is a power supply that is designed to power 12-volt loads in an RV with or without a battery connected, and charge a battery if it is there. Don't try to power 12-volt loads from a battery charger with no battery connected. The chargers have little or no filtering, they depend on the battery to stabilize the voltages.
The simplest way to switch power is with a plug. If you put an outlet powered by the shoreline next to the inverter, and bring your internal wiring back to a plug, move the plug to switch from shore power to inverter and back. Many home-brew generator installs have a generator outlet and a shore outlet next to each other for a keep-it-simple-stupid foolproof system. You can also use manual or automatic switch gear, but your question is a little to broad to get specific on that.
I would advise against powering all 120-volt loads on the inverter when shore power is available and charging the batteries. Unless it's critical and can't be interrupted, like medical or satellite equipment, switch the 120-volt load to the shoreline if it's adequate. The losses in converting the shore power to 12 volts and back to 120 volts will waste some of that electricity, and you will miss the opportunity to give your inverter a rest.
Old 05-06-2009, 09:46 PM   #2
Chassis: Ford B
Engine: 5.9 Cummins Turbo D
Rated Cap: 71
Re: Shore power
I too am just starting to wrap my head around the electrical system that my conversion is going to require. I am planning to do something like this
I am thinking if I include a relay in the circuit between the alternator and the battery bank that will only let it connect to my OEM electrical system when running, and not allow it to drain my 2 batteries dedicated to starting my engine when parked. Maybe a diode as well, so if anything went haywire with my 120 setup it couldn't fry my engine electric.
I have found this site pretty helpful, maybe you will too.
http://www.rv-dreams.com/rv-electrical.html
Thats where I got that diagram and there are other configurations as well.
Good Luck
SlowMotion is offline   Reply With Quote
Old 05-07-2009, 08:43 AM   #3
Re: Shore power
if youlet the electronics people runn the world it would be 5v DC because the components are reliable and relatively inexpensive, unfortunately for items that require large amounts of energy to do work the power company's like AC power because it is much cheaper to make and distribute. that being said, their is no "best" system, you get to choose what is most user friendly for your application, it willprobably be a combination AC/DC system with the battery bank while in transit and shore power wherever you can plug in, use the most energy efficient components and then size the power system to supply it.
unfortunately the energy efficient stuff is expensive upfront, but the long term savings are the payoff.
Old 05-08-2009, 02:21 PM   #4
Re: Shore power
This link might help:
http://rveducation101.com/Articles/B...city_Savvy.pdf
baadpuppy is offline   Reply With Quote
Riddle me this? 50 am shore/generator with inverter too Deacon75 Alternative Fuels | Electric, Propane, Wood & Biofuels 1 06-03-2014 02:36 AM
Grounding shore power to the skoolie's body. kc_4_jc Electrical, Charging and Solar 13 07-04-2011 03:35 AM
Shore power questions! KC10Chief Conversion General Discussions 4 02-28-2007 07:31 PM
Shore power cord storage JonCBrand Conversion General Discussions 3 01-24-2007 01:24 PM
Shore Power rlogan2000 Conversion General Discussions 5 08-02-2004 08:36 AM
