Old 07-22-2012, 08:09 PM   #1
Short bus hauling capibility
Could a short bus with a diesol engine be able to pull a 14000 lb camper, or would the buses frame give out or the engine not be able to handel it.
On the trail to Eagle
thewallfan is offline   Reply With Quote
Old 07-23-2012, 10:18 AM   #2
Re: Short bus hauling capibility
wont hurt the frame.
is camper actually 14,000 lbs? what kind is that?
lotsa small diesel engines/auto trans would not be good for that weight combo, so post yours as well.
Old 07-24-2012, 02:56 PM   #3
its a bus i saw on ebay with a gmc 3500 6.5 diesol. I dont own a camper (but the weight came from a friends palimino puma witch is probaly 30 ft long and has 4 slideouts i think). Couldnt the bus haul a smaller one such as a pop up or one under 5000lb?
Old 07-24-2012, 03:47 PM   #4
it could easily pull a 5K one or a bit more.. much more than that, you would slow down a lot on the hils is my guess.
Old 07-24-2012, 07:54 PM   #5
what would your guess be on the max weight it could haul?
Old 07-25-2012, 03:44 PM   #6
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
my camper is 11,000 lbs EMPTY! and I plan on towing it someday. mind you i aint gonna win the indy 500 with it!
just make sure you get a heavy duty hitch, use a WD hitch and take it easy. keep her legal
Old 07-25-2012, 08:54 PM   #7
Originally Posted by Stuff
keep her legal
dont worry if i do go ahead with the prodject i will.
Wheres a good place to get a hd hitch mounted to something like that.
Old 07-25-2012, 11:54 PM   #8
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
depends on your rig. you dont have it listed. try Uhaul maybe? gotta watch if its a cab/chassis model like mine cause they only go up to class 4
Old 07-26-2012, 02:12 PM   #9
i dont have a rig yet but this is sorta what im looking at
http://cgi.ebay.com/ebaymotors/1999-GMC ... 4aba0686f2
Old 07-27-2012, 04:07 PM   #10
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
should be able to haul just about if not the same as the one ton dually chassis. think of it as a HD 3/4 ton and you should be safe.
My 92 short bus fastnfar Short-Bus Conversion Projects 3 03-07-2010 07:41 PM
short bus 4 x 4 papadoc Short-Bus Conversion Projects 7 09-28-2009 01:02 PM
I'm new here - where can I find info on hauling a motorcycle PirateJohn Conversion General Discussions 6 09-16-2009 07:15 PM
My short bus Firearm Short-Bus Conversion Projects 34 07-21-2009 01:48 AM
Int'l SHORT BUS (VERY Short!) on Craigslist timbuk Classifieds | Buy, Sell, Swap 1 04-08-2009 09:03 PM
