Old 09-10-2019, 07:44 PM   #1
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
Shortest Rear Engine Bus
Im curious what the shortest Rear Engine bus the community has seen in their search for a bus.
I have a 30ft FE but just wondering if there is or if others have seen a 30ft RE?
FamilyCircus is offline   Reply With Quote
Old 09-10-2019, 10:36 PM   #2
IIRC 35' is about as short as they come.
Roll Your Own Build Thread
Old 09-11-2019, 12:38 PM   #3
Engine: CAT 3126
Looks like there might be some that are shorter.
http://www.skoolie.net/forums/f9/31f...ink-18298.html
StatTarget is offline   Reply With Quote
Old 09-11-2019, 01:17 PM   #4
Coachwork: Blue-Bird
Chassis: TC RE 3408
I've never measured it but mine is supposed be 35 foot. It has 10 windows, with an emergency door on both sides. When I got it he had a 29 foot Bluebird FE sitting next to it. In addition to the FE, it had a wheelchair lift, which was also on my don't want list because I just didn't want to mess with one.
But looking at the 29 footer made me think that would be big enough for what I wanted to do, so I asked him if he ever came across any 29 foot Bluebird REs. As I remember that part of a fairly long conversation he basically said not often, and in his experience almost all 29 footers came with wheelchair lifts.
So I went with the 35 footer. And I am still glad I did.
gs1949 is offline   Reply With Quote
Old 09-11-2019, 01:25 PM   #5
Traveling
Someone said someone else said they had a 31.5" bus. No pic or anything to back the claim. Pics or it doesn't exist.
Old 09-11-2019, 02:22 PM   #6
Engine: CAT 3126
rewinding a bit..
are we just looking for info ? or a need/want for a short RE bus ?
Old 09-11-2019, 03:03 PM   #7
Chassis: GA39530
Rated Cap: 40
Just a curiousity
Im just posing the question as a curiousity
Old 09-11-2019, 03:13 PM   #8
Chassis: TC RE 3408
I'm just curious. I think RE buses under 35 feet are pretty rare, and FEs of that length are much more common. So I'm curious to see if that's accurate.
Old 09-11-2019, 03:22 PM   #9
Traveling
I'm sure a short rear engine bus would have issue with it being a lever that will have the front bouncing alot., Weight balance on the steer wheels would be seriously effected.
Old 09-11-2019, 03:35 PM   #10
Chassis: TC RE 3408
Yes, I think there would be a point after which that unbalanced effect would just get steadily worse. I'm very curious to know where that point is, but I suspect it's not too much shorter than 35 feet.
