04-27-2017, 11:08 AM
Engine: DT466E/MT643
Should I bond DC negative with AC ground to bus body?
I've spent some time researching on this forum and others about electrical design but I've been unable to find a consensus on how to properly wire up grounds for a system with parallel AC and DC circuits.
I want to avoid the "hot skin" condition as well as simplify the grounding of my small set of DC devices (LED lights, roof hatch fans, and the fresh water pump). I plan to use marine stranded wiring for the AC circuits.
My proposal would be to ground the DC devices to the body where they are mounted to simplify the number of wires I have to run (hots only) and grounding the 12V power supply to the body as well. Each AC circuit would have a dedicated ground wire all coming back to the power distribution panel which itself would be grounded to the bus body too. AC neutral would remain floating.
Do you guys have any thoughts on my grounding proposal? If this has already been answered I apologize and would appreciate a link to the previous thread(s).
04-27-2017, 11:34 AM
Just found this article that illustrates exactly how I planned to setup my system except I won't have a need for an RF ground.
Getting Grounded the Right Way
04-27-2017, 12:06 PM
let me start by saying I'm no electrician.
imo, there are more than one way to skin a cat. your diagram works fine but the batteries share a ground so they live and die together. you want to find a way to isolate your batteries from each other. battery isolator or....
my bus house has a floating 12vdc+- completely separate from the vehicle, but you have to run 2 wires to everything.
the advantage of floating 12vdc+- is that the house won't short across the bus, only to itself. i can touch the hot house lead to the bus and nothing happens since the circuit is not complete.
the on board battery charger is grounded to the ac side and bus chassis, but the house current floats.
04-27-2017, 12:10 PM
Thanks for that insight. I'm not sure if it matters or not but I'm not actually planning on using any batteries right away. I'm going to use a power supply that converts AC to DC. Typically I have at least a modest AC hookup where I go and I figured I could always complicate the DC system at a later date by adding batteries.
By choosing to forego actual batteries for now I save the cost of batteries, a charger, and an inverter. These are all things I think I can add easily later if I want to do more off the grid stuff, but I also plan to have a generator too, so I may never need battery only.
04-27-2017, 02:20 PM
12v Camping converters are pretty cheap, with battery charger built in.
but imo, if you leave off the battery, you'll only be able to run your 12v loads while the engine runs or you are plugged in. the load will kill you starting battery if used with out assistance. so you are opening up yourself for a problem.
vehicle batteries are tapped out doing what they do for the vehicle. you'll still want to protect your start battery from the house load.
04-27-2017, 04:31 PM
I don't plan to interconnect the vehicle battery with the conversion at all unless you mean that it may drain the starting battery simply because they share a common ground. For now I'm fine with only having DC power provided by my AC power supply when I'm connected to shore or the generator.
04-27-2017, 05:38 PM
Chassis: Blue Bird
Engine: ISC 8.3
Yes, bond the ac ground to the bus body. The ac ground-neutral bond is a bit more involved: when shore power is used, the shore power should provide a ground-neutral bond and the bus should not. However, when portable power is used (most commonly an inverter or generator) then it's your responsibility to ensure that something somewhere provides that bond for you. There are plenty of inverters and generators that do as built by the factory, but plenty also that don't.
One potential problem with keeping systems floating relative to each other is that sooner or later there'll be some piece of equipment that unwittingly ties them. Just as a quick example, a dc-powered TV might be connected to an external antenna which connects to the bus chassis, or a DVD/game console input or AV receiver output with a 3-wire mains plug might provide a path from the dc ground through the ground of the TV's signal inputs to the grounded antenna or mains-powered gear. It won't necessarily create a safety hazard, or even an immediate failure, but those kinds of "hidden" interconnects are something to keep in mind when intentionally isolating systems.
04-27-2017, 06:54 PM
Since I plan to ground both AC and DC together at the body from the beginning I guess we'll see what happens. Good point about the neutral binding. I had read about that. I need to test my generator and if it doesn't I'll wire up a simple plug for that bonding.
Thanks for all the great replies. I'm so glad I found this forum!
06-04-2018, 11:10 PM
Year: 1978
Engine: Detroit 6-71
I'm getting ready to start planning our panel and shorepower for our bus. I bought a 100amp panel with a 100 amp main breaker that will act as the switch to cut power from the source. The source will always be 30amp.
I watched videos on how to wire the panel and one of them said the ground and neutral are bonded at the panel. Below you can scroll through this YouTube and see what I mean.
https://youtu.be/DVc_4PtZXPQ
Is this the proper way ? I know the RV parking panels usually are grounded ..what I'm asking is if I have to bond the ground and neutral in my panel as this video says in a house application? I can't understand this part since I'm doing this in a bus not a house. Obviously when using a generator I would need to ground the generator with. A rod for safer use.
06-05-2018, 05:28 AM
I'm not an electrician so if you are unsure you should consult a professional to be safe. I plan to treat the panel in my bus as a sub-panel meaning that I will keep my ground and neutral separate. I also just plan to ground my generator to the chassis, after all using a grounding rod as I'm traveling down the road to run the air conditioner might get complicated.
1999 International 3800, Blue Bird, conventional front engine, DT466E, MT643
My conversion thread: https://www.skoolie.net/forums/f11/project-huckleberry-17952.html
06-05-2018, 01:01 PM
Chassis: Blue Bird
Engine: ISC 8.3
The general idea with ground-neutral bonding is that there should be only one bond in an entire system, and it should be as close to the source of power as possible.
When the source is grid power, the bond should be in the panel where the grid provider's network ends and the customer's wiring begins. A conventional single-family detached home in the US has just one circuit breaker panel and that's where the bond belongs. Multi-family and commercial installations get more interesting because there are more panels and equipment, but the same idea applies you trust (and maybe verify) that a ground-neutral bond exists somewhere in the system and don't add your own.
When the source is independent power like a generator or inverter, find out whether the source has a built-in bond or whether you should add your own. In my opinion the bond belongs at the generating equipment, not in the breaker panel, because that makes it easier to disconnect the bond if/when the breaker panel is fed from a grid/shore power source.
The electrician in the video Rawlings linked is doing the right thing: he's working in the context of the primary/only panel in a grid-powered house, so a ground-neutral bond there is appropriate.
hatchetman is also doing the right thing: working on the context of an RV which may be grid-powered or self-powered, don't put a ground-neutral bond in the panel. Put it at the generator instead.
At first glance it seems like there's a conflict because both are working in breaker panels and doing different things, but the context outside the panel is the key. One ground-neutral bond per system, as close to the power source as possible. When viewed this way, instead of conflict we see consistency.
06-05-2018, 02:08 PM
Year: 1978
Thanks for your input, so if I will be connecting to shore-power from rv park or from an external generator, based on what I understood from your comment, was that I should not bond neutral and ground since those are already bonded at the RV Park Panel? On the generator side, if I use a generator how would I bond Neutral and Ground in the generator, do I need to open it up and hook a wire that connect Neutral and Ground on the generator which leads to a rod on earth (only if used parked)?
06-05-2018, 02:15 PM
Someone correct me if I'm wrong, but I think this is the simple solution. I think you can just plug it into one of the available outlets.
http://noshockzone.org/generator-gro...utral-bonding/
06-05-2018, 02:54 PM
Chassis: Blue Bird
Engine: ISC 8.3
Right, the jumper plug is an easy and user-friendly way of making the bond by using a spare socket on a generator.
06-05-2018, 03:18 PM
Year: 1978
Okay so that adapter is plugged into one of the 15-20amp plugs in the generator and work even if I plug the generator from 30amp outlet to my 30amp bus inlet?
Now when it comes to RV park, I don't need to do anything right? I keep ground and neutral separate in the bus panel because the ground and neutral are bonded at RV park panel correct? So the do I just plug the ground wires in my bus panel to the panel itself but not used the bond screw just plug them to the side of the panel? Or where do I plug them in?
06-06-2018, 09:57 AM
Chassis: Blue Bird
Engine: ISC 8.3
The panel should have two "bus bars" inside (a metal strip with lots of holes drilled through sideways and a series of screws through the top). One of these will be connected to the metal panel box; the other will be insulated from the panel. The insulated one is for the neutrals; the one connected to the metal box is for grounds. There'll be a place on the neutral bus bar where a screw could be installed through the insulator to the metal panel box. That's the bonding screw. Leave it out.
The neutrals from your outlets and appliances would gather to that neutral bar; the grounds to the ground bar. Use a 3-wire cable to feed the panel: one conductor for hot/line going to the input lug on the panel, one for neutral and connected to the neutral bar, one for ground and connected to the ground bar. This cable can be connected directly to a shore power outlet somewhere, or it can be connected to a generator or inverter.
The shore power connection in an RV park or at home should provide your ground-neutral bond, but as Mike Sokol teaches, it's not a bad idea to confirm the power pedestal is wired properly before plugging in to it.
06-06-2018, 11:24 AM
Year: 1978
Great, you guys are awesome thank you for clarifying this for me. My friend a union electrician just got a hold of me too and verified this. Can't wait to get started on this part of the project. Wiring it this way should keep the bus body from accidently going hot correct, as long as the RV site panel is wired correctly of course right?
