Old 05-10-2018, 05:08 PM   #1
BartStephens's Avatar
Year: TBD?
Coachwork: Looking...
Chassis: TBD
Engine: Seeking Rear Engine...
Rated Cap: Looking for <40'
Should I Buy....2005 Thomas HDX
I would appreciate any advice any of you can offer.
I co-owned a bus years ago and have rented RVs / Airstreams in recent years. Young family of 5 and it is time to convert a skoolie!
I donít know much about engines and transmissions. I can handle some carpentry, electrical, and plumbing. I am no mechanic. I am not doing work myself. Donít have skills or time. I will research options, systems, etc and find someone to help do the conversion.
I am now bus shopping.
I was sold on a RE HDX based on usable interior space, noise, heat, and undercarriage storage. But, Iíve recently read criticism related to bad mirror design (I can replace mirrors) and a recall on wiring system.
Looking for total length around 38ft.
I want to buy the best bus I can find so I have a solid vehicular foundation.
Currently looking at:
2005
Thomas HDX
38í
Cat C7 engine
______? auto transmission
51k miles
Air brakes
Is this a good bus?
What questions should I ask?
What are known issues or standard upgrades to this model?
Any advice appreciated.
Thanks,
Bart
BartStephens is offline   Reply With Quote
Old 05-10-2018, 06:48 PM   #2
Traveling
Depends on what the asking price is. Most of us shy away from anything 2005 or newer due to potential costly and hard to diagnose electrical issues.
Old 05-10-2018, 07:16 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I've an 03 Saf-T-Liner. No problems with mine (so far)
Old 05-10-2018, 07:40 PM   #4
Chassis: Saf-T-Liner MVP ER
Honest opinion?
Awesome bus, horrible engine.
I would pass on the C7.
Now if you find one with the Cummins ISC ...
Steve Bracken
Build Thread
Old 05-10-2018, 08:04 PM   #5
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I agree on the motor.
Old 05-10-2018, 09:20 PM   #6
Year: TBD?
Chassis: TBD
What is wrong with Cat C7?
Old 05-10-2018, 09:22 PM   #7
It's loaded with emissions equipment that they never got to work properly.
It was so bad they redesigned the system and called it the ACERT.
That one was a disaster, and CAT pulled out of the School Bus market.
Steve Bracken
Build Thread
Old 05-10-2018, 09:33 PM   #8
Yep, that's what went down.
I'd avoid ANY newer diesels with the emissions junk. But especially a Cat.
Roll Your Own Build Thread
Old 05-10-2018, 09:35 PM   #9
Life And Stuff's Avatar
So, an old bus is better?
Before 2005?
Hmmmm... Got it.
Life And Stuff is offline   Reply With Quote
Old 05-10-2018, 09:38 PM   #10
Before 2005?
Hmmmm... Got it.
Yes and "old" is a relative term.
Rust is the killer. Few school buses get to the kind of mileage that means everything is wearing out.
So if you get a clean bus with moderate mileage, its age is secondary.
Steve Bracken
Build Thread
Old 05-10-2018, 09:39 PM   #11
Before 2005?
Hmmmm... Got it.
2004 was the year they started transitioning to the really problematic stuff. My 2004 IC has an 03 DT466E so it doesn't have the EGR valve stuff. But an 04 engine would have it.
Old 05-10-2018, 09:44 PM   #12
And EGR is the easy bit. Fairly reliable, and moderately priced to fix if it does go wrong.
I wouldn't let EGR stop me buying (although for those looking, the T444 was never fitted with it), but a DPF .... blech.
That said, some DPFs were retro-fitted to buses, especially California buses. These have the benefit of being able to be removed, and the resale value is high.
Steve Bracken
Build Thread
Old 05-11-2018, 04:17 AM   #13
Year: TBD?
Chassis: TBD
A little help:
DPF = ?
EGR = ?
Old 05-11-2018, 06:26 AM   #14
With EGR, seems the DT's lost some reliability and longevity. Plus EGR engines are more expensive. So are the parts.
I'd definitely avoid ANYTHING Navistar once emissions kick in. There's a reason they're now putting Cummins in IC's.
Old 05-11-2018, 08:30 AM   #15
Year: TBD?
Chassis: TBD
So, would this jury like this model....
http://www.lasvegasbussales.com/scho...ool-bus-b24372
I would like if it were SHORTER. Looking for <=38í
Old 05-11-2018, 08:30 AM   #16
A little help:
DPF = ?
EGR = ?
DPF = Diesel Particulate Filter, fitted to exhaust
EGR = Exhaust Gas Recirculation, sends exhaust gasses back through cylinders to be burned again.
Steve Bracken
Build Thread
Old 05-11-2018, 08:54 AM   #17
Year: TBD?
Chassis: TBD
OK. Thank you. It sounds like the surest bet is a model year before these systems became required (<2004?).
Question, on a later year, could you simply remove these devices if you live in an emission friendly state like Alabama?
Old 05-11-2018, 11:07 AM   #18
Traveling
Used 2003 Thomas Saf-T-Liner HDX School Bus B24372-Used2003ThomasSaf T Liner HDX
That's a $3k-$4K bus.
Old 05-11-2018, 12:37 PM   #19
Same drive trane as my 2002. I am very happy with it. I paid a bit over $3800 including auction fees. 170k miles and it runs and drives great.
However, buying at auction has risks. We have had two members recently that bought at auction and traveled to pick up the bus only to find that it doesn't run.
I think the price on this bus is quite high but I do think that there is some value to being able to test drive and thoroughly inspect a bus before putting your money down.
If you want the benefits of buying from a dealer you should expect to pay more than you would buying at auction but $17k is excessive IMHO.
PNW_Steve is online now   Reply With Quote
Old 05-11-2018, 12:53 PM   #20
Chassis: TC RE
Engine: 8.3L
Also it is a low roof model.
GaryC
Gustav is offline   Reply With Quote
