Old 06-12-2019, 12:41 PM   #11
Originally Posted by Sleddgracer View Post
a tandem axle would be found on a heavier vehicle, not needed on a school bus - more tires on the ground = poorer mileage
Good to know, thanks Sleddgracer
kaivgrant is offline   Reply With Quote
Old 06-12-2019, 12:44 PM   #12
I'd pay like $1500 tops. Low headroom, no air ride, dirty as hell, and from the rust belt.
Other's have mentioned the headroom - how do you know it's low?
Old 06-12-2019, 12:46 PM   #13
Originally Posted by Versatile View Post
Knee deep in rubber. DT466 is a great engine. You don't want a AT545 Tranny you want a MT643. Crawl under it and look for rust.Especially under rear wheel wheels. You don't need a mechanic to go inspect the engine. What condition are batteries? Exhaust? I think a great deal for $1500.00.
Why don't you think I need a mechanic to inspect the engine? I am from out of state so I can't go in person unfortunately. Not new to researching Skoolie's but new to understanding all the nuts and bolts. Thanks for your help!
Old 06-12-2019, 12:55 PM   #14
Can see it.
The wondows are even or lower than the service door and drivers window on low headroom buses.
Roll Your Own Build Thread
Old 06-12-2019, 01:19 PM   #15
Can see it.
Good to know, thanks! Can you tell approx how high the ceiling is?
Old 06-12-2019, 01:31 PM   #16
If they are telling you that the engine is good then you can generally with a DT466 is. You need to know how everything else is. You can park in some lot's and in a day look like that. Add so dew and it gets worse real quick. You won't know unless you go see. Myself i wouldn't buy a bus unseen. Buying unseen is just a toss of the coin.
Old 06-12-2019, 01:43 PM   #17
I went back and looked at the photos again and I can see that someone spent some money on it in the past. Definitely check it out.Where is the bus. Maybe a forum member could go look.
Old 06-12-2019, 01:47 PM   #18
Around 72 inches +/-
Old 06-12-2019, 01:52 PM   #19
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
Myself i wouldn't buy a bus unseen. Buying unseen is just a toss of the coin.'
These two quotes seem contradictory. On one hand, you suggest that if the seller says the engine's good, it is, all because he said so and it's a DT466. On the other, you say you wouldn't buy a bus sight-unseen and suggest doing so is a bad call.
Using this logic, why not just ask the seller about the rest of the bus? His words concerning the engine are apparently beyond reproach. Why wouldn't he be telling truth about the rest of the bus?
And regarding rust, the OP doesn't need to even show up to look underneath. The pictures provided tell the story. If the heavy-metal items pictured havee that much rust, do you really expect the thin sheet-metal to be better off?
- Sharon & Jody
Old 06-12-2019, 02:09 PM   #20
And regarding rust, the OP doesn't need to even show up to look underneath. The pictures provided tell the story. If the heavy-metal items pictured have that much rust, do you really expect the thin sheet-metal to be better off?
What rust are you talking about?
