Re: Should I grind out these rusty exterior screws and repla
Thanks guys, I'm going with the Ospho route.
Step:
1. Sand, Scrape, Wire, Curse rust,
2. Ospho
3. Ospho
4. Ospho
5. Elastomeric paint mixed with the ceramic beads over entire inside: floors, walls, and ceiling.
Once the inside's underway I'll treat and then seal the undercarriage as well.
That's probably a lot more fun to type than it is to do.
The elastomeric paint is supposed to be kind of rubbery so that should be great for sealing and a wee bit of insulation and sound proofing.
I'll probably seal the screw/bolt/nail holes in the floor but I'm thinking that the rubbery paint top and bottom may be enough to seal the small holes. (Not the 2" by 6.5" rust hole in the floor, maybe a good place for a bird's nest).
