Old 05-27-2013, 06:52 PM   #1
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: shower drain trap?
Have you looked at waterless P traps, something like this: http://www.hepvo.com/ .
Old 05-27-2013, 08:07 PM   #2
lornaschinske's Avatar
Rated Cap: 89
"P" trap keeps the nasty smells/gases from filling your living space with the lovely aroma of either stagnant grey water, black tank or park sewer... depending on what you are hooked up to.
We ended up using a standard cheap kitchen sink drain & strainer basket in our shower for two reasons. #1 It was cheaper than the traps I wanted. #2 It was cheaper than a shower drain. Going with a kitchen sink drain yielded two benefits. #1 allowed us to use a smaller drain pipe with out the need to use expensive reducing fittings. #2 I can close the basket drain and soak my feet (I do a lot of standing/walking on concrete floors). #3 We can drop the strainer basket in place and close off the drain while traveling, eliminating to potential smells that may occur because it's so hot outside the highway temps are causing the liquid in the holding tanks to evaporate which smells... bad. Yes, it does happen and part of the reason I never want to travel across Texas in July/August ever again.
It's your bus. Whether you do or don't use "p" traps is up to you. We did.
Fulltime since 2006
Old 05-27-2013, 10:04 PM   #3
Rated Cap: 89
Similar to the Hepvo albeit much older, this worked great in our popup and is much cheaper...
Camco Mfg 37262 Polar White Camper Drain Trap. Sized for Vanity sink and Bar sink drains. Unfortunately David won on this one. We have regular house P-traps. We are putting in stuff a little here, a little there. It had turned out easier to buy one p-trap at a time locally than to order online.
Fulltime since 2006
parasitic battery drain - help?!?! Redbear Electrical, Charging and Solar 8 07-16-2012 08:15 AM
Frame rails as drain traps? bus-bro Conversion General Discussions 5 04-22-2012 10:45 AM
P-Trap / Hepvo Waterless Valve lornaschinske Conversion General Discussions 0 04-15-2011 01:20 PM
Cat 3208 coolant drain? paul iossi Caterpillar Drivetrain 2 11-11-2009 01:32 AM
Shower Stalls, Shower Stall Pans Ryan Grimm Conversion General Discussions 6 05-18-2006 04:57 AM
