Originally Posted by Clayton
I have a 1996 Thomas and I cant seem to get the side windows out. I removed the retainer clips from the inside and cut the caulk. No amount of pulling seems to allow these to come out. Any advice? It is cold outside I'm sure that makes things tougher but they should come out. Thanks
Hey, we have a 91 and had the same problem. If you look inside the channel on the windows check for some little screws in there, we had them. After that it was just a ton of pulling.
Sent from my XT1575 using Tapatalk
