Old 08-23-2007, 06:36 PM   #1
Skinning...Sheet metal, where, what and why?
I plan on raising the roof on my bus 12-16 inches. I will make the final decision as to how much when I finish gutting it. I plan to try and get this done before the weather sets in up here in the Cascades. After the roof is raised I would also like to get the sides skinned and the windows and door set. This would leave me a shell to work inside of (and under) this coming winter.
What gauge sheet metal is best to use when filling in the sides of the bus when the windows have been removed? Why that gauge? Where is the best place to purchase it? Do you order it cut to size or does it come in sheets?
I am also wondering about riveting the metal together...it seems that is the preferred method but I have worked with steel stud framing for many years and have screwed that together. Has anyone tried wafer head self-tapping screws by chance?
Rattles what methods have been found to quiet them? Backing the sheet metal with 1/4" plywood, foam or sheet insulation? Probably a combination of all three..
Caulking...what type is best?
Anything else I have forgotten?
All replies will be read with great interest.
Thanks!
Abbott is offline   Reply With Quote
Old 08-26-2007, 11:42 AM   #2
Re: Skinning...Sheet metal, where, what and why?
I have found a great website here. It will calculate material sizes (sheets up to 4'X 10') for you, weight and price. Many different materials to chose from. The down side is the materials I need are to large for them to ship UPS but the website still offers good pricing information. If you live in Minn. or Fort Worth Texas you could pick up your order yourself.
http://www.discountsteel.com/
Old 08-27-2007, 12:01 AM   #3
I see nobody has replied to this, so I'll give it a shot and a bump.
Shipping of steel would be expensive. Look in your Yellow Pages for "steel", "steel suppliers", "steel fabricators", etc. Or find a local welder. A welding shop can order what you need from their local steel warehouse operation, and usually buy enough that they get free delivery on a weekly schedule by the distributor's company trucks. The steel supplier should be able to shear it to size for you. Places around here will shear a sheet once for free, and charge per cut after that. Shearing will give you the cleanest/straightest cuts. Most of the sheet goods come 4x8' and/or 5'x10'. Plan the height of your lift, and the size steel you order to cut from, so you have the least amount of scrap... (12"/16"/20"/24" will all evenly divide into either 48" or 60" wide stock). You don't want to have to pay for the 6" strip left over if you, for instance, order 3 pieces 14"x8' cut out of each 4'x8' sheet.
I would go with something along the lines of 22ga (real thin, IMO too light for this) 20ga, 18ga, or maybe even 16ga (thickest of the 4, and starting to get on the heavy side).
I saw a good tip somewhere on this board about preheating your panels with an infrared heater to get them hot, so that after you screwed/riveted (work fast) they would then contract and tighten up and be wrinkle-free and not oilcan.
waywardfool is offline   Reply With Quote
Old 08-27-2007, 12:23 AM   #4
I agree shipping is out of the question. I included the link as it calculates price and wieght of several different materials and gauges, which I thought was helpful. I will find a local source.
I am looking at a few options, 18ga. with some light gauge angle iron reinforcement. 22 to 24 gauge over 1/2'' plywood. Or RV/Travel trailer siding over 1/2" plywood. I have another week or two of prep work to do before I raise the roof so that gives me some time to research and plan the skin. I have 6' 4" of ceiling clearance right now, so I think I will raise the roof 14". That will give me all the room I need for insulation, much more room for upper cabinet storage and that "open" feel to aid the floor plan.
Old 08-27-2007, 04:54 AM   #5
find a local sheetmetal shop, go in the shop (not the main office) and talk to the shop foreman. You'll get your best deal like this. Ask about a product called paint-grip or paint-prep. 18 or 20 gauge will be sufficient. Good luck!
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 08-27-2007, 10:07 AM   #6
I had read over your website awhile back and remembered the mention of "paint prep" but I could not recall which site I had read about it on. I have it book marked now. You used 20 gauge metal then? That would sure be nice to work with, what did you back it up with, angle iron, flat stock, plywood? Did you have any rattles? Very nice looking conversion you built there.
Old 08-27-2007, 03:32 PM   #7
On my last bus, I didn't skin the windows, I painted them black from the inside. I'm a sheetmetal worker (specialty fabricator specifically) so I do things of this nature quite often. I recall seeing someone else on the site here who I believe used 20 ga. The actual name of the type of metal in question is galvannealed. It is a form of galvanizing that is specially prepared to accept paint and offer the corrosion resistance of galvanizing. Paint-grip and paint-prep are brand names. It's great stuff. I formed my under-bus propane storage out of 12 ga. paint-grip and never got around to painting it. It looked just as good a year later with no additional protection. I'd be careful with heating panels and then riveting them on, the contracting metal can produce enough force to shear or worse, partially shear your rivets and possibly lead to future failure of the rivets. If you leave posts between the windows, you shouldn't have to add any additional bracing.
Brad Davis
"Big Blue"
Old 12-01-2007, 09:43 PM   #8
Chassis: All American RE
Engine: Cummins 8.3
This thread has some great information. After looking at available metal, I am wondering what the difference between "cold rolled" and "hot rolled" is and which would be preferable for bus skinning. Any ideas?
thanks - Tony
dentarthurdent is offline   Reply With Quote
Old 12-02-2007, 12:04 PM   #9
good question!
Cold rolled starts out as hot rolled and then goes through another rolling process after cooling that gives it a slight work hardening and a smoother finish. It is more expensive. Hot roll has a finish that is good enough for most uses, But I'd strongly recommend a galvannealed metal to protect the backside of the panel that won't be painted. (galvannealed is coated hot-roll)
Hope this helps clear things up.
Brad
Brad Davis
"Big Blue"
Old 12-02-2007, 03:55 PM   #10
Engine: Cummins 8.3
ah ok - thanks for the explanation! Just to clarify, Is there such a thing as cold rolled galvannealed metal (rolled after being coated)?
Old 12-02-2007, 07:19 PM   #11
Not that I'm aware of. If you're concerned about surface finish, galvannealed metal has a nice smooth finish.
Brad Davis
"Big Blue"
Old 12-03-2007, 06:31 PM   #12
Engine: Cummins 8.3
excellent - thanks again!
Old 12-03-2007, 09:35 PM   #13
reprobate's Avatar
Thanks dentarthurdent for reviving this post. I hadn't seen it before. Just today I ordered 6 sheets of 20 ga. paint-lock for my skin. Should be here Thur. Will be finished welding about then and be ready to apply. As a sidebar, I see a lot of talk about caulks on this forum and haven't seen any mention of NP-1, NP-1 is the baddest caulk on earth IMHO and I will be using it pretty much everywhere I need to use caulk. It's a urethane caulk that all metal roofers(at least the ones in this area) and many in the sheet metal world swear by. Adheres much better than silicone and stays resilient longer without releasing . Will be great for all joints and pretty much every where else. So for your joints or other areas dentarthurdent, check the local roofing suppliers or talk to some local sheet metal shops if you are interested. Can't wait to here how your project turns out.
reprobate is offline   Reply With Quote
Old 12-04-2007, 09:06 AM   #14
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Hey guys,
Sorry for hijacking this thread, but I was wondering about the appropriate thickness, of aluminum, for skinning windows.
Thanks for any help.
Robert
Roasting8 is offline   Reply With Quote
Old 12-06-2007, 05:41 PM   #15
aluminun is usually referred to by thickness in inches. I'd recommend .040 to .063
Brad Davis
"Big Blue"
Old 12-07-2007, 09:31 AM   #16
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Thanks Brad, for he information. I'm still trying to decide whether I want to skin the windows or just keep them painted.
Thanks again.
Robert
Old 12-08-2007, 09:29 PM   #17
You're welcome! I'm still trying to decide that also. However, I did recently buy some rv windows, so skinning is looking possible.
Brad Davis
"Big Blue"
Old 12-09-2007, 07:58 AM   #18
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
I wish you luck on the skinning and putting in the windows. I'm going to wait until I'm able to get some low priced RV windows before I decide to skin my. Besides, I kind of like the look of my present windows (not to mention, it's a lot less work ).
Thanks again,
Robert
Searching for sheet metal M1031 Classifieds | Buy, Sell, Swap 1 04-11-2011 04:00 PM
Sheet metal work opus Conversion General Discussions 1 02-02-2011 04:40 PM
Sheet metal and dimples swhite832 Conversion General Discussions 13 02-10-2010 04:25 PM
Sheet metal over windows... staggerlee917 Conversion General Discussions 27 06-08-2009 02:22 PM
Sheet metal guage for windows Billsman Conversion General Discussions 12 05-13-2008 04:39 PM
