Old 09-06-2012, 06:37 PM   #1
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: skinning the side and caulking...?
Punted to Conversion Discussion. And free bump.
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 09-06-2012, 06:57 PM   #2
Engine: 466DT
I used locktite brand of adhesive caulking. I don't remember for sure exactly which one. I used it when I reskinned the windows. Seems to be working good and no leaks. Still alittle flexable. Its been almost two years and 4000 miles. Got it at lowes.
Hvbuzz is offline   Reply With Quote
Old 09-06-2012, 11:02 PM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Without pics, your bus doesn't exist.
I'm hungry!
You Gotta Let Me Fly
Old 09-07-2012, 10:07 AM   #4
most peoples busses dont exist since the gallery went away....
Old 09-07-2012, 12:39 PM   #5
Moderator
crazycal's Avatar
It's still not working? I hadn't been there in a while.
I'm hungry!
Old 10-23-2012, 02:24 PM   #6
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
I used liquid nails at each point where I riveted 2 or more pieces of metal together. I did that more to keep rattling down than anything else. It seems to have worked pretty good.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 10-23-2012, 08:46 PM   #7
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
This is my plan... which may change....
I am going to rivet (more of them) and then drop in the windows which will probably need some square tubing and more rivets and will then pack the open areas where the windows were with polyiso sheet insulation then fir them out.
All of this hoping the sheet wont rattle?
What do you think
Old 10-28-2012, 11:46 AM   #8
kimberlink's Avatar
Engine: DT466 / AT545
Rated Cap: 71
Should there be some sort of caulking between the metal skins and also the skins and bus body?
The most terrifying words in the English language are: I'm from the government and I'm here to help.
Ronald Reagan
https://s1253.beta.photobucket.com/us...k1961/library/
kimberlink is offline   Reply With Quote
Old 10-28-2012, 06:03 PM   #9
bapos's Avatar
Can one ever seal things up too good?
Skinning your bus. Any regrets? crazycal Conversion General Discussions 13 10-22-2012 08:55 PM
Skinning over windows lornaschinske Conversion General Discussions 2 11-24-2010 03:30 PM
Caulking windows Doodlebug Conversion General Discussions 5 12-27-2009 10:30 PM
WINDOW SKINNING captainkf Conversion General Discussions 2 05-04-2006 12:36 PM
skinning the side and caulking...? MotorPark Skoolie Conversion Projects 0 12-31-1969 07:00 PM
