Old 11-22-2019, 01:43 PM   #1
Chassis: IH 3800
Skip the subfloor?
Hey guys..
Working out some details of our interior build out. One of our big issues is headroom. We can't afford to lose any.
Once we pull the interior sheet metal, we'll have room for proper insulation without losing height... but the floor on the other hand, not so much.
The original floor was just a rubber mat over sheet metal. My plan is to repair the sheet metal... seal/prime/paint... then go over it with a quality underlayment.. possibly some 1/4" fan fold... then a quality moisture proof laminate floor. I also have quite a bit of Damplifier Pro sound deadener that I may put down under it as well. It's a great thermal/noise barrier.
Anyways.. I strongly doubt we'll ever be traveling distance in the winter so I'm not overly worried about the floor getting cold. Are there any other concerns that I'm not thinking about that would demand the need for a subfloor?
Old 11-22-2019, 01:49 PM   #2
brokedown's Avatar
I don't see a problem with that, beyond the obvious and expected lack of insulation value. I'm personally thinking about a this XPS layer with a relatively thin t&g faced plywood + stain + polyurethane floor, hoping to get it all done in an inch.
Old 11-22-2019, 01:52 PM   #3
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Our original floor was plywood under the rubber mat, somewhere around 3/4" thick total. We used 1/2" foam board insulation with furring strips, 9/16(?) OSB and then some click laminate wood flooring. We still have the original floor in the workshop and it's only a slight (1/4") difference between the original and new sections.
Dave
Old 11-22-2019, 02:24 PM   #4
Chassis: IH 3800
I did something similar on our short bus and it worked decently but it had more headroom than our big bus does. Our big bus didn't have any wood.. just sheet metal and ~3/8" rubber. I figure with a good underlayment and some fan fold, we'd probably be around 1/2-5/8" which would fine for what we are doing.
Old 11-22-2019, 09:26 PM   #5
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
At least remove the rubber. That stuff is GROSS
Old 11-23-2019, 06:18 PM   #6
Chassis: IH 3800
Yup. Rubber is up and the metal under will be repaired and sealed.
-NotSoGrand Garage-
https://www.youtube.com/channel/UCjw...WCpE8n6fLiplJA
