09-02-2017, 09:16 AM
Skylight and roof vent questions
Does anybody have any recommendations for what brand of skylights to use to replace the current emergency hatches? Also what brand exhaust fans have you guys seen work best? I'm at the point where I'm ready to paint my roof and figured I'd do all the roof stuff at once. ANY advice wold be appreciated.
09-02-2017, 02:55 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
E-hatches are 23.5" square. RV hatches are considerably smaller.
As for exhaust fans, try a radiator fan with shroud.
09-02-2017, 03:09 PM
Thanks capt squid I'll check those out
09-02-2017, 03:22 PM
- Roger (Dog.Rescuer)
09-02-2017, 04:25 PM
That's a good idea thanks for the pictures dog rescuer .
09-02-2017, 08:25 PM
Year: 98
09-03-2017, 01:56 AM
I paneled over the chintzy roof hatch on my shorty. Will be installing a Fantastic vent. Just put one in my work van and I LOVE it.
Easy to install and really does a great job.
09-03-2017, 02:08 PM
Rated Cap: 37,400 lbs GVWR
I'm thinking of converting my rear roof hatch / emergency roof exit into a simple skylight, using a marine skylight on top of the existing Transpec surround that's attached to the roof. I would like to be able to see the stars when lying in bed! I haven't found a 24" square marine skylight yet, but I haven't been looking too hard now - there's a marine salvage place near here that may be worth a visit.
09-03-2017, 09:26 PM
Chassis: Thomas
Engine: CAT 3126
I just did exactly this today!
09-03-2017, 09:27 PM
Man, its great isn't it?
09-03-2017, 09:31 PM
Chassis: Thomas
Engine: CAT 3126
I haven't had a chance to really enjoy the results yet, but it looks good and blows well!
Sent from my SM-N900P using Tapatalk
01-02-2019, 07:17 PM
Originally Posted by joeblack5
where did you get the cover for the hatch?
01-02-2019, 08:51 PM
Chassis: 12m (40') coach
Engine: Mitsubishi 16L V8
02-17-2019, 01:28 PM
Hatch
Doggie window off amazon. Wanted to share it since I searched high and low for ideas on this topic.
03-19-2019, 06:43 PM
Coachwork: Thomas Bus
Chassis: Allison MD 3060
Engine: Catepillar 3126B 210hp/605 ft lb
still looking for clear "bubble"
I just want a plastic 24x24 bubble clear to replace my emergency escape "door" without disturbing the frame. Surprized I see none on line with a lip around it (so it doesnt leak). Dont want it to take any time installing it.
I have spent some time looking to no avail! The marine hatch looks pricey and requires installation. I want roof access AND lots of light.
03-19-2019, 07:22 PM
You might try grafting on to the hatch door something like this.
https://www.ebay.com/itm/RV-Skylight...UAAOSwuxhbm9qn
03-19-2019, 08:09 PM
hoping to not make a frame. Too bad I cant find one with a lip! Looks like a solution if no lipped ones like on 14x14 skylights exist! thanks
03-19-2019, 08:15 PM
What was wrong with the one I posted. It is 26" x 26". I would cut the lip at the screw holes, cut a hole in the hatch top and secure and seal it to the hatch lid. Done.
You're not looking very hard.
Here's a 14" x 14" with a 16" lip.
https://www.ebay.com/itm/RV-Skylight...oAAOSwOMtbaKOJ
03-19-2019, 08:17 PM
Chassis: IH
I believe the OP is wanting something that can be opened/closed.
I do too, for that matter.
03-19-2019, 08:22 PM
I don't believe what he and many of us want is made commercially. Take either of the 2 skylights I posted and cut a hole in the hatch lid and secure the skylight to the opening. You know have a hatch that has not changed in performance other than letting clear light in. What am I missing here? Maybe I should go in business and make replacement hatch lids in Clear or tinted Lexan.
