Old 10-02-2019, 09:23 AM   #1
Chassis: MVP ER
Slow draining fuel filler
I replaced my rusted tank with a plastic one and increased the total capacity from 60 gal to 100gal. My filler neck is 2'' and I used 6-7ft of 2'' hose to connect to the new tank. At the tank connection it necks down to 1.5 using a reducer. I have a 3/4'' vent line going back up to the top of the filler neck, the vent line connection on the tank may be a little small as I think is has a couple of 1/4'' holes in the tank part. I tried to fill the new tank yesterday and had slow drainage of the fuel form the filler neck, it took around 5-6 mins to get 10 gallons into the tank.. There is only around 6 inch drop from the filler neck to the opening the tank. Is there a certain slope that is needed or does the vent line at the tank need to be drilled out larger. Any help would be appreciated.
ism minerals is offline   Reply With Quote
