Re: Smog Pump???
an alternator, a steering pump, water pump, then a thing that looks like an air compressor--with piping leadding to your first air tank. is it diesel or gas? crawl under and trace the lines (pipes). no one around here has ever talked about a smog pump, so i assume it's the air compressor. needless to say, don't remove it until you know what it is.
