Old 01-09-2012, 06:14 PM   #1
Smoothing out a modified sine wave AC signal
Decided to post this in it's own thread, rather than in the electrical help one. Has anyone experimented with smoothing out a modified sine wave signal? In theory shouldn't the right size capacitor do just that?
icnivad is offline   Reply With Quote
Old 02-01-2012, 07:42 PM   #2
Chassis: TE2000 FE
Engine: 5.9L Cummins
Re: Smoothing out a modified sine wave AC signal
Problem with a modified sine wave inverter is its a stepped voltage. To date I have never heard of anyone smoothing one out for less money then an equivelent sine wave inverter.
Chcuk
cschlessman is offline   Reply With Quote
Old 02-06-2012, 06:37 PM   #3
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
The other poster is correct.
You also would have to tear apart the oscillator and up the freq. and other mods the"smooth" the MSW converter - then after all that you would now have a sine wave inverter.
Better to buy one it the first place or where you can run things off of 12 volts.
Computers laptop no problem; desktop you would have to change out the AC power supply and install a DC to DC power supply - you can find them on eBay.
TV LCD etc. There are ones made to run on 12v but are expensive.
I am getting up enough courage to open my LCD TV after the warranty expires and after the power supply check the voltage and current; if workable make a 12v supply using DC power supply.
Bullwhacker007 is offline   Reply With Quote
Pure Sine VS Modified Wave Inverters TygerCub Conversion General Discussions 8 08-05-2012 09:06 PM
Modified sine wave for a fridge? Diesel Dan Heating, Cooling and Appliances 15 06-12-2012 11:53 PM
turn signal gasket somewhereinusa Conversion General Discussions 5 06-02-2012 01:43 AM
looking for 4 way flasher/turn signal relay syke Conversion General Discussions 13 05-24-2012 12:40 PM
Sine wave inverter alert Ob1 Conversion General Discussions 6 09-22-2010 08:15 PM
