Old 08-26-2009, 04:44 PM   #1
TygerCub's Avatar
Engine: Detroit
Re: Solar Furnace
You could put a row of those under the windows along the side of the bus and as long as that side is facing towards the sun, you'd be able to heat the bus pretty well.
Interesting idea.
Since the cans take up quite a bit of width, another idea may be to use either a half can (difficult to cut, though) or a row of copper tubing painted black. Shoot, for that matter, almost any thin walled tubing would work as long as it's: A) painted flat black, and B) covered by an air tight clear covering that traps the sun's heat in an insulating air pocket.
Old 08-26-2009, 07:22 PM   #2
TygerCub's Avatar
Engine: Detroit
Re: Solar Furnace
Another interesting thing that you can do if you plan to stay in any one spot for more than a day or two is to create a mini "green house" effect on the side of the bus. Using thin emt conduit and a thick greenhouse plastic, just create a lean-to over the sunny side windows. This will allow you to trap the warmer daytime air next to the bus as well as block any heat-stealing wind from the base.
Or, combine the two concepts.
The possibilities are endless, really.
Solar ovens and solar water heaters/showers tomas_maly Heating, Cooling and Appliances 6 05-22-2013 11:43 AM
furnace qs timbuk Heating, Cooling and Appliances 14 01-27-2011 07:53 PM
Is this furnace adequate for a mid-size bus? roach711 Conversion General Discussions 8 09-30-2010 09:59 AM
Mounting Suburban Furnace BUSBOZO Heating, Cooling and Appliances 3 04-07-2010 06:36 PM
Diy wood/water furnace? gotmuddy Conversion General Discussions 12 05-16-2009 09:24 PM
