Old 01-17-2020, 08:29 AM   #1
Solar Mounting
I知 planning on installing 7/8 Unistrut on the roof for solar panels. I知 running it longitudinally. I知 considering 8mm blind stainless steel rivnuts with a rubber seal. The skin of the bus is .060 aluminum. I was thinking of a nut every 2 feet.
Is that going to be strong enough and stay watertight?
Thanks
Old 01-18-2020, 11:04 AM   #2
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Seems rivnuts would be useful for something you plan on removing more than once. Is that the case?
We're doing something similar w/ unistrut, but it will support both panels & a catwalk. My plan was to simply bolt through the roof into the ribs, & seal with 3m 5200. Of course we have access to both sides at present (gutted).
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 01-18-2020, 05:46 PM   #3
Yeah, I’m starting to think through bolting through the ribs is probably a better way to go. I saw on McMaster Carr sealing washers. I thought that I will through bolt with a carriage bolt, then the sealing washer on the outside, then some sealing stuff (sikaflex?), then the unistrut, a lock washer, and a nut
Old 01-18-2020, 09:22 PM   #4
3M™ Marine Adhesive/Sealant 4000 UV
Old 01-19-2020, 12:19 AM   #5
Rated Cap: 37,400 lbs GVWR
My roof walkway (to which my eight panels are hinged) and the panels' lower supports are all bolted through the roof ribs with 3/8" and 5/16" stainless bolts from underneath, with EPDM washers sealing against the roof. So far so good - after several winters of sometimes very heavy rains I haven't had even one single drip coming through all those roof penetrations. I would NOT trust just the roof skin to hold against the wind when driving at 60-plus MPH - that's almost hurricane-force wind. You've got lots of strong roof ribs, more than on any other vehicle on the road, so why not use them?
rivnut
