Old 08-11-2014, 10:16 AM   #1
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Solar Panel Tilt Mechanism -- Looking for ideas.
Still in planning stages for my conversion and am now looking for ideas for a solar panel tilt mechanism that can be actuated from either inside the bus or outside from the ground. I do not want to have to climb up on the roof to tilt the panels.
My bus is a Crown Supercoach II, so the roof has a pretty rounded arch to it. I plan to install four DM Solar 12-volt panels in-line along the crest of the roof. So a single axis tilt is probably the way to go, and just plan to park the bus heading east whenever possible. This will allow all four panels to tilt toward the south.
Thanks to Handy Bob for suggesting hood lift cylinders. If they have enough lift perhaps a tension system would be sufficient to control tilt. I'd want to add a remote latch to keep them battened down during travel or windstorms.
My tilt mechanism can be motorized or manual. The key is to not have to climb up on the roof. I welcome any and all brainstorming ideas.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 08-11-2014, 10:57 AM   #2
Re: Solar Panel Tilt Mechanism -- Looking for ideas.
I've had good luck with 12 volt linear actuators available on e-bay. Probably a good idea to put them in an expandable water proof sleeve if they are going to be exposed to the elements. Jack
Old 08-11-2014, 11:23 AM   #3
Locutus's Avatar
Thanks Trunt. Good idea on the actuators. Perhaps if I were to use them in combination with the hood lift cylinders I could get by with just one. That leaves the batten-down latch mechanism to figure out.
Locutus
Old 08-11-2014, 08:31 PM   #4
I had the same issue with my pop top which tilts open on the actuators. I made threaded pegs from carriage bolts. The pegs are welded to the pop top frame and drop through holes in the roof and mate up with holes in the bottom of stainless steel "cups" mounted upside down in the inner roof metal. When the top is down I spin a wing nut on the peg to secure the top against its seals. When the top is open I stuff a plug in the now empty hole in the cup. I had also considered an electric trunk latch from an old Caddy. Jack
Old 08-12-2014, 12:16 AM   #5
lornaschinske's Avatar
Rated Cap: 89
Ever look at the crank up mechanism from an RV off-air antenna?
The big question is would you realize enough gain from being able to tilt as opposed to not tilting? Rather than tilting, perhaps just adding an extra panel or read up on Handy Bob Solar. A tilted solar panel makes a nice windcatcher and could go sailing off the roof (not that the one I saw actually left the roof... just blew around punching holes).
Fulltime since 2006
Solar Panel mounts ErrabundusBus Conversion General Discussions 2 10-13-2014 04:52 AM
Solar panel question Stuff Everything Else | General Skoolie Discussions 1 12-11-2012 07:13 PM
Solar panel/array sizing? tomas_maly Electrical, Charging and Solar 1 09-17-2012 12:23 AM
Solar panel setup TygerCub Electrical, Charging and Solar 16 03-15-2012 12:50 PM
Solar panel, power gathering experiences paul iossi Electrical, Charging and Solar 1 06-08-2009 11:15 PM
