Old 08-28-2006, 10:33 AM   #1
Steve's Avatar
Solar vent
Anyone any experience with these?
http://www.campingworld.com/browse/p...nt/prodID=5548
Looks like a nice and easy way to add vents to your bus without needing to run wires to the roof.
Old 08-31-2006, 02:44 PM   #2
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
confused
I am a tadd confused. Where does it vent to? In the pictures the to looks sealed and therefor nowhere to vent to. Right? If it does work, it looks slick. -Richard
captainkf is offline   Reply With Quote
Old 09-01-2006, 07:59 AM   #3
Here’s a better set of pictures of that solar vent ….
http://www.cetsolar.com/smartvent300.htm
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 09-02-2006, 09:57 AM   #4
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Thanks, that's a much clearer breakdown. It looks good, but I wonder how much air it would actually move?
-Richard
Old 09-02-2006, 10:17 AM   #5
Richard according to the specs that fan moves 40 cubic feet of air a minute (CFM)
Old 09-02-2006, 09:54 PM   #6
The Slims's Avatar
Air Exchange Rate
The key is determining the volume of your bus then calculating the number of exchanges that can occur in a given period of time. For example, my bus has 1175 cubic feet slap empty, subtracting the volume of any large items (counters/storage/benches/etc) provides a more acurate result. At 40 CFM it would take almost 30 minutes to exchange all the air in the bus, theoretically. With two fans (properly located) I could get more than 4 exchanges per hour. The target exchanges/per hour is up for debate as I don't have any guidelines there; however, 4/hour would probably go a long was to prevent excessive heat/moisture build-up. In greenhouses exchange rates can be as high as 60/hour in the summer and as low as 2/hour in the winter, but these are not really comparable figures. Hope this helps!!!
1985 International 28 Passenger
6.9L Diesel/Allison AT-545
The Slims is offline   Reply With Quote
Solar ovens and solar water heaters/showers tomas_maly Heating, Cooling and Appliances 6 05-22-2013 12:43 PM
Vent Info rex_1_mn Heating, Cooling and Appliances 2 09-30-2012 08:16 PM
Solar power vent fan lornaschinske Electrical, Charging and Solar 2 03-24-2012 09:09 PM
What is this vent......... Funkpirate Conversion General Discussions 5 04-15-2010 10:46 PM
Looking for a used vent. Bus Project Conversion General Discussions 0 02-11-2010 09:25 PM
