Old 07-29-2015, 12:17 PM   #31
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Going out on two house boats, they tie them together and we dance on the upper deck
Old 08-29-2015, 11:49 AM   #32
Chassis: AARE
We're on our first trip of any length since I brought the bus home from NM. We're at a campground on the KY/TN state line. We aren't in any particular hurry and the first night stayed at Big Lick campground just south of Cincinnati. I wanted to avoid interstates just to see more scenery so I set the gps for shortest route which went quite well. The last 10 miles or so was on a "scenic" road that wound around and went up and down a lot. Not sure what we would have done if we would have met another large vehicle.
I had written down the number for the alternator belt a number of times, thinking I should get a spare, but never seemed to quite get around to it. I did try to get one the day before we left, but there wasn't one in town. It's one of the multigroove types. When I checked things over the first night it had lost some of the backing and frayed the "v" off on one side. Before we left the "big city" area the next morning I spent some time looking for one to no avail. Since it only runs the alternator and is a mechanical engine I have enough battery to run quite some time so we pressed onward. The belt is still working so it getting home should be no problem. I did find some in SD so should be home when we get there, I ordered two.
I did an overhead last week hoping to improve fuel mileage, it's hard to tell because I'm pulling a Land Rover which is a bit heavy and there were some pretty long hills. Found some fuel for $2.19 and mileage was 6.7 last tank before that was 6.8 on flat ground not pulling anything, so I'm pretty sure mileage has improved.
I'm a little concerned about transmission temps. It's an Allison MT643 with external filter and a fluid to water cooler. Temp fluctuates quite a bit running between 200 and 250 and on one occasion was about 280. I think the first order of business would be change the fluid and filter. Have been doing some research, one suggested that adding a tank adding about 3 gallons extra did the trick on the same transmission on the long western mountains.
All in all the trip is great, the mountains didn't really slow us down that much, the weather is great, the mini splits work great, mama is happy. What more can you ask for? Life is good.
Dick
Old 08-29-2015, 09:51 PM   #33
Engine: 190hp 5.9 Cummins
Glad to hear your out enjoying the scenery.
Old 08-30-2015, 10:18 AM   #34
Good luck with the tranny temp thing. Do keep an eye on it. Anything above 250 radically shortens the fluid life according to Allison (just looked for the online chart I saw but can't find it...sorry). And there is also a lot of discussion going around about fluid types these days. Seems the old Dexron III is no longer in favor and the "new improved" stuff like TranSynd is more desirable. Also a lot more expensive.
Best of luck with it and let us know what you discover.
Old 08-31-2015, 09:47 AM   #35
Chassis: AARE
We made it home last night with no problems. Funky belt made it all the way. Took the"big" roads home, trans temp is lower when I can keep speeds up on the much more gradual grades. Mumsywumsy even volunteered that she had a good time. New AC works great, when I first turned them on got it way too cold in here. They ran for 2 days, if the radio is on the only way you can tell they are working is that it just stays cool inside. The rear condenser is under my bed, I have NEVER heard it run. I did try running one from a cheap chinese 1500w pure sine wave inverter that is connected to a couple of optima batteries just to see if it would work. Worked for about 1/2 hour until inverter shut down for low voltage.
Old 09-01-2015, 12:32 AM   #36
Cool test.
Old 11-21-2015, 02:16 PM   #37
Chassis: AARE
Last trip of the year.
I'm on my last trip for the year, might be longer than expected. Had a photo shoot last weekend and stayed this week to visit with friends, do some dancing and work on dog training. Seems I might have made a bad decision. It's about 7 inches last night and still snowing. Mumsywumsy is not happy if I don't make it home for thanksgiving.
The infloor radiant heat works great. It's toasty warm in here and I haven't gotten all of my insulation done yet, very little in ceiling. Just going by feel, the water temp at the end of the loop is cooler than that going in but, still too hot to hold your hand on. The longest loop is the coolest. My infrared temp gauge took a crap so no real measurements.
Got a lot of good dog work in, and went dancing two nights, decided not to dance in Madison tonight, it's 80 miles away.
Here's a pic of the bus, with Molly moving the sheep up to get water.
Molly bringing another group up.
Not planning on leaving until Monday, supposed to get above freezing.
Dick
Old 11-22-2015, 09:25 AM   #38
Coachwork: IC
Chassis: CE300
Rated Cap: 32
WHOA!
looks frigid!
we moved back from Indiana when it got cold.
Old 11-22-2015, 09:58 AM   #39
REDD's Avatar
Coachwork: Thomsass
Chassis: Freightshaker
Engine: 5.9 cummins 5 speed
Rated Cap: 6 passenger 2 ATV's
Got snow last night as well, bummer! Come on May!
Old 11-22-2015, 12:01 PM   #40
Cool pic man.
We have snow here already too.
Glad to hear your in floor heating is working well.
Somewhereinusa somewhereinusa Skoolie Conversion Projects 383 10-09-2017 10:25 AM
Props to be thrown to somewhereinusa bapos Forum Admin | Account Help | Suggestion Box 0 06-23-2013 11:54 AM
